Washing machine - drum off-center, screeching sound in spin cycle
we have an old commercial washer in our house. It's a Wascomat Junior W75 Double Loader. It's been working fine for 3 years and counting.
Lately, though, we have been noticing a screeching sound coming from the machine during the spin cycle. Upon closer inspection it looks as though the drum axle is slightly off center as the drum wobbles slightly both during regular and spin cycles.
Please check out these two videos I recorded to illustrate the problem.
http://www.youtube.com/watch?v=8TD4gaPbB74
http://www.youtube.com/watch?v=hkIPX5pmtQk
I am wondering whether this is serious or a normal condition. What can I do to fix this?
All tips and information would be very helpful - thank you!
- Henrik
    Brigadier General:
  • 3,917 Answers
Hi, Probably you need to level it with a 2ft or 4ft level, be sure to check it on all 4 sides. Or the wobbling is normally caused by defective dampers. Just like car suspension, these even-out the vibrations of the drum. When worn, the drum just bounces wildly on its springs. The metallic banging should be avoided by foam buffers fitted inside. These frequently fall off unnoticed. They just need gluing back on with impact adhesive. Check this site nd rotate the cursor on the parts to see the diagram of damper... http://www.repairclinic.com/Washing-Machine-Front-Load-Frigidaire-GE-Kenmore-Style-Appliance-Diagram Let us know if you were looking for something more else please accept the suggestion. Thank You for contacting Fixya.com
Posted on Feb 08, 2010
Can I safely use my washer if I hear something metal scraping during spin cycle?
You can, but I wouldn't. The outer skin of the drum is made of plastic. If it is a coin, it could dislodge, get caught again in mid spin and punch a hole straight through the plastic.
Get a flashlight and look between the seal and the outer drum when you open the door.
Jan 24, 2016 | Frigidaire Washing Machines
Wascomat W-125
Search craigslist, ebay, and google the part number to try and find a used replacement part. Search for refurbished electronic control boards companies online.
Feb 07, 2014 | Wascomat Parts Wascomat 990251...
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
AGGITATOR NOT WORKING AND THE SPIN CYCLE NOT WORKING ALSO LOOKING FOR TEARDOWN INSTRUCTIONS.
how old is ure machine if it is about 5 years old and the drum is strugglin to spin u will need your motor brushes changing
Feb 03, 2010 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Jul 30, 2009 | GE WSXH208A Front Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
"Sreeching" sound when trying to spin.
? Is the drum free to turn with your hand?closes Eire
Dec 05, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
