My girlfriend has an lg vue phone for at&t and she has a micro sd card but it will not let her save files like pictures and text messages so she cant set up files for certain people in her phone
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost textmessages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Facebook Homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Google+:https://plus.google.com/communities/109657948177651590858
Did you try the File Manager ?Applications > Office > File Manager : there you'll seeC: Phone MemoryE: Mass Memory F: Memory Card you can move your files manually & very easily using this file manager.
1 Either using bluetooth, which can't be too large a file/picture.
2 Next would be to take out the micro sd card and put it in it's adapter and put it in the computer and transfer the pictures;
3 send an email with the picture attached in the email. Send it to your 10 digit nextel phone number @messaging.nextel.com and when you get the text and open it the picture should be there, then just save it to you phone or card.
Can you describe in more detail what you are trying to do, step by step, and how the process is failing?
I have uploaded and downloaded pictures from my micro-SD card, both while it is in the phone, using a USB cable and setting the phone to "Menu | Settings & Tools | Tools | USB Mass Storage". Then the phone and the micro-SD card appear on my (Windows) computer as a removable drive, and I can just copy files in either direction.
I am also able to remove the micro-SD card, and plug it into an SD-card slot on my computer (with a micro-to-SD card adapter), and it mounts as a removable drive that way, too.
Note: if you have the micro-SD card in the phone, and you want the pictures you take to be stored on there so you can download them in one of the ways I've described above, then be sure to go into "Menu | Settings & Tools | 9. Memory | 1. Save Options | 1. Pictures" and set this option to "Card Memory", or else your pictures will get saved in the camera internal memory, and not on the card. This may be your problem if you are not seeing the pictures you expect on your memory card when you look for them. If you take Videos and/or Sounds, you might want to set those "Save Option" to the Card Memory, too.
There are a couple of ways that you can get photos from blackberry to computer. The first is a memory card such as an ( sd or micro sd card) youwould have to have the photo's stored on the card then to transfer would be take the card out of the phone. then you will need a memory card reader on or connected to the computer. Put the memory card in the reader then with the computer on hit start button then click computer find the card tab open and right click on each photo or edit select all highlight right click on the whole page save as file then name that file before hitting save on the save window. or drag and drop onto a file in your picture files. also if you have a wireless network you could send them from your phone to computer, but a really easy way to solve this is send a photo text message to your email as many times as it takes. It does work type your email in where the phone number goes when sending a text to someone. Best of luck.
1st - Place the SD card in the phone. Make sure card is not larger than 8gb. 2nd - Adjust the setting to save Pictures, Video, Music to the SD card by going to Settings and tools > Memory > Save Options. 3rd. Remove the SD card from the phone and connect to PC. Now on the PC you will see the phone has created folders for you "Music". 4th - Drag your music files into the correct folders (ie music, pictures, etc). 5th Place SD card back in LG Envy 2 and enjoy the music.
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
You can save the text messages into the computer using the software from Motorola. Motorola Phone Tools allow you to transfer all the information between the cellphone and the computer. You can get it from store.motorola.com Also remmber that you are not gonna be able to save text messages or contacts information in a memory card. The memory card allow you to transfer just Multimedia stuff as music pictures or videos. Good luck
If saving to a micro sd card just use a card reader hooked to your computer . if not get a micro sd card and dont save to the camers built in memory , you can use up to a 2 gb card .
