Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Replace Control Board?
Dishwasher has error code CL which indicates the door is not shut. Of course the door is shut. The door switch is working properly. I confirmed that power is making it back to the control board on P8 from the door switch. Seems like a relay or other component on the control board has failed. Any other ideas?
randysroberts@gmail.com
    President:
  • Frigidaire Master
  • 2,651 Answers
Control board sounds like alikly source, been known to have problems with their display boards as well though.does your unit have a display board on the front maybe 2in.x 3in. square inlay? or is ti just kinda all part of the push button leds
Posted on Feb 23, 2008
My dishwasher FDB2510LCC1 get a cl code while washing and stays running on the wash stage until it is shut off
Hello Randy, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher is displaying an error code of "CL" this means close door. The dishwasher may not be sensing that the door switch is closed. The "CL" means that you could have a possible issue with the main control board or door latch. I would recommend checking to make sure the latch does not have any visible damage. This could also be a miscommunication within your dishwasher and a reset may help clear it out. In order to reset the dishwasher you would flip the household circuit breaker off for at least ten minutes. We hope this information is helpful to you. -Matt
Jan 28, 2016 | Frigidaire Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
I have a Frigidaire dishwasher model # FDB2415LFSO with a blinking CL code. When I try the normal wash cycle button the drain pump runs and the CL light blinks continuously and nothing more happens. The...
Good Afternoon friend, thank you for your post!
Based off what you have described you have performed multiple tests to your Frigidaire dishwasher and it continues to display a "CL". That code does stand for close door which can mean that the door switch is sensing it is opened. For this error code it could be a possible problem with your door switch or main control. I understand you stated that the control did not appear to have a burn inside of it so it is easy to assume that the door latch could be the issue. Remember if you are not a professional technician this could be the start of unnecessary part purchases. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
Why won't my dishwasher start?
Thank you for your inquiry, friend!
Based off the information you have provided "CL" stands for close door. If you continue to experience an issue with the "CL" error code I would recommend having a professional come out to your home and diagnose your appliance. "CL" could be a problem within your door switch or main control board. Hopefully this is helpful. -Matt
Aug 28, 2014 | Electrolux Dishwashers
Frigidaire Gallery Professional Series GPD8998JC0 ... I can press the buttons to choose my settings but my START/CANCEL button won't work. So I try a 1 hour delay which works but then no water nor the...
Hi Joseph - I understand your dishwasher is displaying a "CL" error code. A "CL" code typically refers to the main door switch. The first easy troubleshooting tip is to flip the circuit breaker to the dishwasher for about 20 minutes and see if that resets it and clears the error. If the circuit breaker trick doesn't work, it could potentially mean that the door is not closed completely. However, it could also mean that the control board is not sensing that the door is properly closed. I would recommend checking the door switches. Look to see if you notice if anything is bent or misshapen. Also, you might try the manufacturer site to see if you can download an owner's manual for future reference. They typically have a large number of owner's manuals for consumer use. If you have tried these troubleshooting tips and still come up with a "CL" code, you might need to reach out to a local service tech who can better pinpoint the problem for you. Best of luck!
Dec 19, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire dishwasher model FDB2320REC0 when I push the normal wash CL flashes
Hello linda_ross88 - Typically CL indicates that the main control board is not sensing that the door is properly closing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, typically an expert would need to check the door switches, wiring, and test the main control board. Regrettably, this is not a simple DIY job. I would strongly recommend seeking a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 18, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
It says CL washing and obviously isnt working
Hi
Daniel
Nov 26, 2010 | Frigidaire 24 in. PLD3465REC Stainless...
Kenmore elite calypso waher
The "PF" error code indicates a power failure to the dryer. To clear the error code, press Stop/Cancel.
If the Stop/Cancel button does not clear the problem you will need to replace the control board on the dryer. The part number for the control board is 3976611, in case you need it.
Ob code = out off balance
cl code =
If the door is securely closed & the CL error code appears, I would recommend checking the door lock switch & wiring harness to the door lock switch. Other possibility; control board.
Dec 17, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
367 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
