Question about MSI 845GVM-V (MS-7057-010) Motherboard
Power is not going to processor as the smps is ok
Plz cheek on off swoch
Posted on Feb 09, 2010
5 Suggested Answers
  • 263 Answers
SOURCE: It is not booting
some times that is due to a bad heater zink that colds down the prosessor so you have to be sure that is properly seat with the compound on top de prosessor to avoid air gaps that is a thermo protection from the prsessor.... than check the memory on the slots for proper attachment
Posted on Dec 27, 2007
SOURCE: no display smps ram Processor ok
yes i have tried comos battery and clrtc jumper the problem is that no display
Posted on Mar 27, 2008
rpspls490
  • 24 Answers
SOURCE: cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Posted on Oct 13, 2008
adampune
  • 125 Answers
SOURCE: My Smps is ok, when i switched on smps fan and
Check Following Instruction:
1. If your SMPS ok, Check 20 pins cable connect properly to the motherboard, or Fan 4 pin connect to the motherboard.
2. And Start your Motherboard. It will OK.
Posted on Apr 13, 2010
Every thing is working fine but no display as i changed the display & also checked the same display on another set it is working ok changed display ic but still same problem
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Apr 01, 2011 | Computers & Internet
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
By voltage imbalance in processor it get very high heating so its going very temperature my sysetem hang out after running in 5min
if problem is high voltage so power supply change but you see both fans is ok, smps fan and processor fan.
no dust under processor heatsings.
Apr 23, 2010 | ASUS K8V-MX Motherboard
My Smps is ok, when i switched on smps fan and processor fan not on
Apr 13, 2010 | Intel Motherboard
CPU does not turn on..everything is plugged in..power cord is plugged into a working socket. what are my options?
its 2 cable that need to be plugged in from the power suppley, the wide cable and a 4 stick cable. both to the mother board. also you need to connect the fan cable to the mother board. how do you know that the processor doesent start ?
Oct 26, 2009 | Computers & Internet
AsRock Motherboard won't boot. Need Advice.
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Jan 10, 2009 | Computers & Internet
Cpu not starting up....power 2 cpu from smps is ok..
Oct 03, 2008 | Intel Motherboard
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
MSI 845GVM-V (MS-7057-010) Motherboard Logo
88 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
