Question about Dishwashers
Water is not being sent through the arm/blades during the wash cycles.
  • 534 Answers
More than likely the water pump control has gone out.Due to the location of this part it would be easier to have a tech look at it since the pump is located in an akward area
Hope this helped
Dave
Posted on Feb 08, 2010
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
Soap is not disolving. Falls out of holder and stays on door and floor of washer.
Are dishes also not coming clean? Most likely, there is not enough water chruning in the tub to rinse soap out of cup during wash cycle. Sufficient wash action will wash the soap out of the cup and dissolve it in the water within a few seconds of the cup opening.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Does not pump water during the wash cycle.
It sounds like you are on the right track.
Open the dishwasher, remove the bottom rack, then remove the thumb nut in the middle of the unit that secures the lower wash arm and housing. Look for debris and clear any you find. Try again. If no joy, you will have to repeat the first step and also remove the wash pump upper housing that is secured with torx head screws. Same thing after you remove it - look for debris in the impeller area and remove it.
If you have to remove the wash impeller, you will need a 1" offset box wrench and as I recall a 1/4" socket. The 1" offset box wrench is needed to keep the impeller from turning while you remove the center nut. You will also need to remove the upper discharge line retainer clip to get that out of your way. Inspect the impeller for any debris and especially cracks or missing blades. If the impeller is damaged it will need to be replaced.
While you have this thing apart, check the lower wash arm and upper wash arm discharge pipe assembling for any obstructions.
I am assuming the motor runs ok and the timing cycles seem normal.
May 03, 2009 | Dishwashers
Dishes don't get clean. soap still on inside of door. . . water coming up to fill line and hot enough and dishwasher drains after cycle, spray arms are clear. . . help!
Water from the wash arms must be able to reach the detergent cup during the wash. It sounds as though the machine may be over-loaded during the wash and water does not cause the detergent to mix with the wash tank water. Try washing a cycle with nothing in the machine. Does the detergent still stick to the door?
If no, the machine is overloaded. Wash fewer items or smaller items so spray will contact detergent.
If yes, you have probably lost wash pressure. Clean all screens and jets.
Hope this helps,
Kermit
Aug 13, 2008 | Dishwashers
Maytag JetII dishwasher
try removing the wash arms( should be a center mounter ***** that releases the wash arm. possible that hte holes in arm have become clogged w/debris. although oyu cant seperate the arm try getting the debris out from the large center hole.
Mar 11, 2008 | Maytag 24 in. MDB8750A Jetclean II...
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Machine runs through cycle but does not wash dishes
It sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck
Aug 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Jun 20, 2006 | Danby 22 in. DDW399 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
