Question about Hotpoint WMA74 Front Load Washer
How to change bearings on hotpoint wma74 - Hotpoint WMA74 Front Load Washer
  • Archie Amphlett May 11, 2010
    Remove top from machine. remove soap draw, then remove front door seal from front panel. On left sid of control panel remove 4 screws located where soap draw came from. this panel will then come away by gently pulling from left hand side. If you want to romove alltogether then make note of wire positions.The door lock can also be removed by undoing 2 screws just inside door panel. Now remove 3 screws along the top of the front panel, Also 3 screws at bottom of this panel now panel will lift slightly and come away from machine. Now remove the top front piece by removing screws, and pipe which is attatched to soap box. At back of machine remove the lower panel, then remove pipe from bottom of tub, all wiring will need to be unplugged making note of positions. To make thing a little easier you may want to remove concreat block from top of tub. The tub is now ready to lift out from machine, lift upwards to release top springs, and the shocks under tub then bring tub forward, take care of wires and motor. The tub then splits into 2 halves. Try and remove bearings before you purchass new ones as there are 2 differant sizes fitted. If youget stuck you may emailme at archie4805@yahoo.co.uk and I will try to help. this is by no means an easy job.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 27, 2010
3 Suggested Answers
prawinmv22
  • 106 Answers
SOURCE: My wma74 Hotpoint WM door will not open
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
rate me
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: Hotpoint WMA74 does not pump out after programmed
No test available other than:
Remove pump - check motor will turn by rotating impellor. There is a slight resistance then moves freely, then slight resistance and freely again. This is correct for this machine. worth checking there is no hair, elastic band or other obstruction around the impellor fins and shaft whilst the pump is out.
There is no spin cycle so you have to use rinse & spin, which means if the pump is shot you need to empty the machine each time :(
Worth checking lower filter as stated and blowing down the drain hose whilst the pump is off to check for obstructions.
The resolution to my problem was a new pump - £20.
All working fine again now !
Posted on Jan 25, 2010
Hotpoint wma74 washing machine fills with water then does nothing will not run drum or spin
hello it sound like the brushes on the motor could be the cause 2 plastic blocks sit either side of the motor these are made of carbon and wear down can cause the motor to stop working also the other causes could be interlock on the door and module control board hope it helps
regards
shaun
May 24, 2011 | Hotpoint WMA74 Front Load Washer
Started to get a whinning, grinding noise on starting the machine and especially on spin cycle. is it the bearings and how much to repair?
yes it sounds like the bearings are damaged due to the ingress of water. It's a costly job, but if you're a good diyer you could try it yourself.
Oct 09, 2010 | Hotpoint WMA74 Front Load Washer
Hotpoint wma74 wont spin
It could be the motor's carbon brushes have worn out. Replace with the same type. Need to get at the motor, you simply unscrew and slide out. If they are hard to reach then you will have to take the drive belt off and remove the motor and then take them out. These brushes provided the electricity to the motor in order for it to spin.
Aug 09, 2010 | Hotpoint WMA74 Front Load Washer
Very little water on wash cycle
water level is determined by the pressure system, and no adjustment can be made.Ensure your programe is not selected to half load.
Feb 18, 2010 | Hotpoint WMA74 Front Load Washer
Jan 24, 2010 | Hotpoint WMA74 Front Load Washer
We have a Hotpint WMA74 - water gusting out of powder/liquid compartment at top when spins - have changed drain pump - but still happens - can you help?
It sounds like you have a partial blockage somewhere..
Remove rear panel.
Remove large black hose onto drum.
Check and clean filter inside hose.
Remove drain hose, and check for restriction here as well.
Please rate my solution.
Thanks.
Nov 17, 2009 | Hotpoint WMA74 Front Load Washer
rate me
Jun 12, 2009 | Hotpoint WMA74 Front Load Washer
CHILD LOCK STUCK ON
I agree with the initial solution, depress the child lock button for at least 3 seconds.
If it does not clear, then try again.
Good luck.
Thanks.
Feb 12, 2009 | Hotpoint WMA74 Front Load Washer
Where can I get a manual for Hotpoint-Ariston WMA74
In your browser bar type in the following:
hotpoint user manuals, then click on manuals user guides and click on user manual , find your model and download to your computer or print it off.
Plz leave feedback for this solution.
Dec 15, 2008 | Hotpoint WMA74 Front Load Washer
Hotpoint WMA74 Front Load Washer Logo
686 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
