Question about Maxtor Hard Drive
5-yr old Maxtor 160GB fw/usb down
One of my two identical 5-yr old Maxtor One Touch 160GB is down.
The one unit continues splendidly, but the failed unit is unresponsive.
The green pilot light on the wall-plugged power supply changes from
Lit to flashing when the Maxtor drive is switched on.
The blue pilot light on the front of the case does not light at all.
Exchanging power supplies with the healthy drive yields the same result;
good drive works, bad drive makes power supply flash; so the problem
is not with the power supply.
  • Jerome Beesley
    Jerome Beesley Feb 26, 2008
    I'll try swapping the logic boards - good idea.
I was wondering if swapping circuit boards actually worked ?
Posted on Sep 25, 2008
    Genius:
  • 1,019 Answers
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
Posted on Feb 23, 2008
  • Mike Waldron Feb 27, 2008
    Thankyou for your Rating,
    Any Problems or further Help. just Re-Post Here.
    Good-Luck Mike @ Compurepair.
I need driver for maxtor onetouch III
Probably more than just a driver, but Maxtor is part of Seagate, so you should be able to find driver on Seagate's website. I had a 500gb Seagate that failed within the warranty. I didn't want to send it in with loss of all data, so I took it apart. Wala, drive was ok, the interface had failed. If the driver doesn't help Good chance power supply or interface is the problem and drive is ok.
Feb 27, 2015 | Maxtor 160GB OneTouch III Mini USB 2.0...
My Maxtor 250GB just stopped working all of a sudden. When I connect to the computer, all it does is a whirring sound like it's trying to boot up, but it does not open so that I can access the data. What...
Best to Download Seatools from the Seagate website. You probably have a 5 year manufacturer's guarantee and you can test and possibly repair it with Seatools before having to returning it with Seatools results to get service, which is only free if Seatools finds it Faulty.
Dec 12, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I have maxtor one touch tm 4 mini 160 GB hard,i i want to download its driver but no where i found it.from which place i can download its driver.
If it is the Maxtor Manager you need then it is all explained here:- http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-mini&vgnextoid=7fd5783de3444110VgnVCM100000f5ee0a0aRCRD
Dec 06, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I cant find sofotwaer Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive
Nov 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Mator one touch 4 mini 160 gb software, I accident...
Maxtor Manager is not available as a download but you could email Seagate to try to get the files
May 20, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Install driver of maxtor 160gb onetouch 4 mini
Hmmm What software do you need?
You should not need software to run the HDD. Just plug it in.
You can get the One Touch software from Seagate (who no own Maxtor) See
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
HTH
Dec 08, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
http://hddlist.com/maxtor/all/maxtor_basics_portable
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor STM3050040TA3E5-RK ; FW 400/USB
The Maxtor clever pragrams will not work but you should be OK just plugging it in, you might need disk utility to format it,
May 21, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor Hard Drive Logo
141 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
