Question about Samsung SGH-A137 Cell Phone
I have set up Speed Dial keys. Now, however, I can't navigate to keys 3 and 7 to change them. The navigation keys do not go one item at a time. Instead they jump to the bottom or top of the list. How do I get the navigation keys to go one item at a time on the list?
  • Samsung Expert
  • 2,973 Answers
In the settings you would find an option of Reset to Factory Default. Do that and all your settings would be set to factory defaults. A word of caution here. Back up all your data on the phone. Back up to a PC to be on the safe side. Then reset to factory defaults and then start setting the phone again. And if possible stay away from Speed Dial till you can.
Posted on Feb 08, 2010
Nokia 302 change language
Find "Device language"
  • Press the Navigation key.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Device and press the Navigation key.
  • Scroll to Language settings and press the Navigation key.
  • Scroll to Device language and press the Navigation key.
2. Select language
  • Highlight the required language and press the Navigation key.
3. Exit
  • Press Disconnect to return to standby mode
Jul 06, 2014 | Nokia 6220 classic Smartphone
Tip
HOW TO ENTER SERVICE MODE MENU TO PANASONIC TVs
This is the way to enter service mode menu to most of the Pansonic TVs.
1. Press and Hold Down the [Vol-ve] key, on the front panel of the TV set.
2. Press "Recall" button on the remote control three times.
The service menu window will appear.
3. Use digits [1] & [2] keys on the remote control to navigate Main Menu items.
4. Use digits [2] & 4] keys on the remote control to navigate sub Menus.
5. Press [Vol+ or Vol-ve] keys on the remote control to change the data value to selected item.
6. Power OFF the TV, by its main Power ON/OFF switch to save the adjusted value into memory and to exit from service menu. When you switch ON the set for the next time, it will come alive with adjusted parameters.
on May 20, 2012 | Panasonic Televison & Video
Speed dial
Select CONTACTS, press left or right hand navigation button until the FAVOURITES tab appears. Scroll down to the number you want to allocate as the speed dial key, use the ASSIGN key to assign the contact you want to associate with that speed dial key.
Jan 24, 2013 | Samsung GT-C3520 Unlocked Quad-Band GSM...
How to reset samsung s w299
Restore factory default setting
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
My curve 8520 is typing on ots own! it keeps appear sign a speed dial to the V key what is that???
hi honeymadoo and welcome to fixya,
you need to change the settings of your phone, usually there is key navigation assigned, maybe you pressed it that way, please do check your phone settings.
thanks and have a nice day
Jan 05, 2011 | RIM BlackBerry Pearl 8100
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
I want to change the name (My caller ID)when I fax how can I do that It show up as Holy Dreams that name of our former company. I want it to show as our new company. How do I do that
I believe you wish to change the "Station ID" on your MFC-240C. This setting will print out your company name and other header info on your faxes:
1) Press the <Menu> key
2) Press <Up> or <Down> Navigate to "Initial Setup"
3) Press <OK>
4) Note: Your station ID is already set, therefore the machine will prompt you to choose: (1) change, or (2) exit without changing - choose (1) to change
5) Enter your fax number, then press <OK>
6) Enter your company name using the dial pad keys. This may take a little practice. Press the dial pad key the correct number of times to produce your desired letter. Use your (>) right navigation key to advance to the next space. If you entered a letter incorrectly and want to change it, press the left navigation key to move the cursor under the incorrect letter.
7) Press <OK> when finished
8) Press <Stop/Exit> to resume normal operation
There! You should have it. I hope this helps!
Brother MFC 240C Station ID
Mar 03, 2010 | Brother Multi-Function Center MFC-240C...
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
NORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
Jun 17, 2008 | NorStar Meridian M7310 Phone
I Have a Cannon, Laser Class 710, Super G3 Fax Machine and need to know the procedures to reset the time and date. Can't find my manual.
lift up the 3 speed dial panels
use Data registration key
select date/time settings
use the 4 direction arrows to navigate thru menus
and after changing info use set key to lock in setting
let me know if ya need more help
these are great faxes
May 23, 2008 | Canon Office Equipment & Supplies
Samsung SGH-A137 Cell Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
