Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wont drain or spin.. the washer drum looks like it has dropped in the washing machine, it seems to be sitting lower than usual
I have the same problem. Let me know if you find a solution mark.beard@yahoo.com
Posted on Feb 09, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Why wont it spin and drain
if its a front load washer check the drain pump,if it cant drain the water it will not go into spin cycle,depending on make/model the pump can either be accessed from the lower front or rear areas under drum inside the machine
Feb 19, 2012 | Washing Machines
My washing machine drum wont turn. The washing machine fills with water then just sits with water in it. It will drain but wont spin It worked fine yesterday, but today nothing. When I turn the drum by...
hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
Jan 03, 2011 | Hotpoint WMA13 Front Load Washer
I have a whirlpool washer lxr7144e01 the water drains out but it wont spin. It looks like the drum is not sitting level anymore. You can hear something runing under the drum.
the drum support spring/s have come off,,letting the drum drop a few inches,,take the top or back off and the support springs can be put back on or new ones fitted,,the springs fit into the top of the washer case and hook onto the drum
Jun 28, 2010 | Washing Machines
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Won't spin
We had it checked out and it was going to cost over $500 to fix. Thanks!
Jul 10, 2008 | LG WM-2277HW Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
232 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
