Question about Belkin F5D8236-4 Router
Is the Belkin N Wireless Router (F5D8236-4) compatible with Windows 7?
  • 4,281 Answers
Yes it is compatible for all windows version after windows xp.
IF you want to configure it follow below direction.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 08, 2010
Testimonial: "Thanks so much for answering my help question. I did have to get further help, because I am not so computer savy. Thanks again, Dot"
I have a belkin f5d8636a.4 wireless router and need to connect it to a new computer running windows 7 using a belkin f5d8053uk usb stick. i need to know are both these items windows 7 compatable or do i...
The Router supports a variety of networking environments including Mac OS® 8.x, 9.x, X v10.x, Linux®, Windows® 98, Me, NT®, 2000, XP, and Vista®
usb stick OS Compatibility: Windows® 2000, Windows® XP 32 bit, Windows Vista® 32 bit
Nov 28, 2017 | Computers & Internet
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
HI,
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
My toshiba laptop does not connect with my belkin router, as did my friends toshiba laptop, i have windows vista and my friend has windows 7 and neither seem to work? Can someone tell me if toshiba's are...
Definitely Belkin is compatible with all the operating systems. the issue is the security type that came along with the router is WPA/WPA2... it is not compatible with many computers. Changing the security type to WEP64 bit will work perfectly...
Dec 20, 2010 | Belkin Wireless Play Router (F7D4302)
Can not set a password in G modle FSD7231-4 useinf vigin network and windows 7 home 64 bit
ok let we setup again your wireless security to compatible with your windows 7
Connect the computer to one of the four gray ports on the back of the router.
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
setup wireless security in to 64bit WEP
Sep 19, 2010 | Belkin (F5D7231-4) Wireless Router
How do i make my windows 7 laptop compatible with belkin router?
Routers do not have any Windows 7 compatibility issues. Simply plug the cable in the ethernet port, and set the IP address to DHCP.
If you want wireless, you will need to configure the wireless network in Windows 7. There is a wizard in Windows 7 for that.
Dec 22, 2009 | Belkin (F5D5231-4) Router
Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to www.bioticaindia.com and download a win 7 driver there. They show a 48% success rate.
Dec 13, 2009 | Belkin Computers & Internet
Are there new drivers for teh Wireless G Plus MIMO USB adapters for windows 7?
From Belkin's Support web site: Windows 7 Product Support Information Windows 7 users:
If you are using an older Belkin Networking product, you may not have support for Windows 7 with your current software. Please visit your product specific support site to check for updated Windows 7-compatible software for your product.
Software updates will be posted as they become available. Please check back if your product is not currently supported.
Some updates may still be in the process of going through Microsoft’s official certification program. Although they have been thoroughly tested, they may present a warning message when the driver is being installed. These drivers will install on 32 bit operating systems but not on 64 bit systems, which is the normal and expected behavior.
http://en-us-support.belkin.com/app/answers/detail/a_id/2742/q/network-adapters
Nov 22, 2009 | Belkin Wireless-G Plus MIMO Router with...
Belkin n adaptor will not work with windows 7
Download the Drivers For Vista2_bing.gif 64 Bit From
www.belkin.com/support
Step 1 : Right Click on the exe File And select Properties
Step 2 : Click The Compatibility Tab
Step 3 : Select Run this Program in compatibity mode For Win Vista SP12_bing.gif
Step 4 : Click Apply
Step 5 : Now try to install it
Nov 08, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Connecting my router
windows vista is probably too new for the belkin wireless g router u bought. did u see if the logo on the box is compatible with the windows? 2nd if its a weak signal then you might have to buy a N1 router member it depends how much the signal can spread
Jun 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin F5D8236-4 Router Logo
1,037 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
