TV turns off by itself
Mitsubishi big screen tv model TS-5545. It went off and when turned back on, immediately switches off. what is wrong with it?
  • sunshyn46 Mar 18, 2009
    I have the same problem the TV turns itself off. You have to wait 10 minutes .Then try to turn it on. It works for us, NO idea why it does it.
  • 8,617 Answers
Try pushing in input and menu together and holding them in on the set for 5 seconds to se if the led blinks a code. hen let me know what the light blinks if anything.
Posted on Feb 22, 2008
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi ts-5545, Black screen and Heart beat
A couple of things:
1) Either a bad power supply or a flyback 'supplies the high voltage to the 3 CRT's' .
2) The HOT 'High Output Transistor' is gone bad or the leads 'solder joints' have cracked and are not making a good connection.
time to get it into the shop or have a tech come to your residence to look at it.
Good possibility of getting it fixed.
A/V Media Guy
Nov 22, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Unable to turn tv on and of.
if no parts is available have it converted, since it is only a switch. any switch will serve its purpose as long it has the same power rating
Jul 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Has sound but no picturemodel ts 5545 mitsubishi
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
