Question about Philips Televison & Video
My tv is stuck on the menu option I can get it to go off for a few seconds but them it just flips back
  • 566 Answers
Hi erin
I`m gonna help you with you problem but first i would need the model number of your tv set ?
And are you using a cable box?
Posted on Feb 08, 2010
Monitor will cycle through the menu screen every few seconds after being turned on.
the menu button is stuck,use a sharp knife to pry the button out very lightly,not all the way out,just enough to make sure that it isnt stuck,if it still happens then the board for the menu button needs to be replaced
May 27, 2015 | HP w1907 LCD Monitor
Tip
RESET ALL CODES AND PRESETS
IF YOU GET LOCKED OUT OF YOUR TV OR ITS MENUS IN ANY WAY USE THE REMOTE AND 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THE SCREEN WILL FLIP BLACK FOR A SECOND AND THEN HIT MENU A FEW TIMES TO BACK OUT OF THAT TASK. THIS IS THE UNIVERSAL V-CHIP FOR THIS TV AND MANY OTHER RESETS.
on Sep 21, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
The menu options keep poping up
I doubt this is a user fix. There is a problem in a mother board .
I would run to the warranty and try to replace it.
Mar 09, 2014 | Televison & Video
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
Cuisinart CBK-200 Turn on flashes 3:15 and won't let me choose another menu I thought it was becuase I pressed start prior to picking another menu option so turned off the poiwer for 15minutes to flush out...
This is normal behavior for this breadmaker to default to 3:15 - just press and release the MENU button a few times to advance through the menu options. If it is "stuck" and won't advance through the menu options, hold in the stop/pause button for almost 15 seconds until the machine resets back to 3:15. THEN, press and release the MENU button a few times to make your selection.
Jul 28, 2009 | Cuisinart CBK-200 Bread Maker
Turn on flashes 3:15 and won't let me choose another menu option
Jul 19, 2009 | Cuisinart CBK-200 Bread Maker
Menu Screen turns on/off on its own...alsoTv video flips through
The front panel Tactile Switches need to be replaced. Replace them all. This should be the part #. 23344507. You can order it through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Jul 01, 2009 | Toshiba 32AF43 32" TV
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Samsung HLN437W
REPAIR: Enter the service mode; under option menu DDP1010 (DDP1011, where
applicable) adjust the V-Flip option back to normal. If the problem continues
replace the DMD Board
Mar 02, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
