Question about Brother QL-500 (Bundle) Thermal Label Printer
Trying to download QL500 driver for Windows 7 64 bit. Pressing unzip does not put the unzipped file in the folder. can you help please.
    Scholar:
  • 77 Answers
Go to www.download.com & download and install 7-zip.
http://download.cnet.com/7-Zip/3000-2250_4-10045185.html
Right click your downloaded file and choose extract to this location.
Posted on Feb 08, 2010
Install myanmar font
How to install and use Zawgyi Myanmar Font
  1. Download Zawgyi Myanmar font and keyboard driver here.
  2. Find and Unzip the downloaded file
  3. If you know how to unzip the zipped file, skipped to Step 4.. Otherwise read on.
    1. How to unzip downloaded file
i.You need to have file compression software to zip or unzip the file.
ii.If you have winzip or similar software, you can use it to unzip
iii.Otherwise download z-zip application here
iv.Double click on 7z444.exe
v.Click Install
vi.Click Finish
vii.Right click on the downloaded file
viii.Select 7-Zip, then select "Extrace to"ZawGyiFont\" and it will create a "ZawGyiFont" folder.
  1. Installing ZawGyi Myanmar Font
i.Inside the folder, you will see the following.
ii.Click "Start" then "Setting" and select "Control Panel"
iii.Double click on "Font" folder.
iv.Copy the "Zawgyi-One-20051130.ttf" file and paste it to the "Font" folder above and finish the font installation.
  1. Keyboard Driver Installation
    1. Open the "ZawgyiKb_installer_I" folder under "ZawGyiFont"Folder
  1. Double Click "ZawgyiKb.msi" file and installation is completed.
  1. You sill need to set up Zawgyi Myanmar Keyboard driver to type using Zawgyi Myanmar font.
  1. ZawGyi Myanmar keyboard setup
    1. For Windows 2000
i.In Control Panel, double click on "Regional Options"
ii.Click on "Input Locales" tab and click "Add"
iii.In the Keyboard Layout/IME: drop down menu, select "Zawgyi Myanmar Unicode Keyboard" and Click "Ok" then Click "OK" on "Regional Options" window
iv.Keyboard installation completed.
  1. Windows XP
i.Open "Regional and Language Options" in the Control Panel
ii.Click on "languages" Tab and click "Details"
iii.Click "Add"
iv.Check "Keyboard layout/IME: check mark and select "Zawgyi Myanmar Unicode Keyboard" from the drop down list and press "Ok"
v.Press "Ok" on "Text Services and Input Languages" window and press "Ok" on Regional and language Options" window
  1. Testing Zawgyi Myanmar Font
    1. Open a blank word document.
    2. Select Zawgyi-One in "Font" drop down list.
    3. Type some words, and try Ctrl+Shift OR Alt+Shift to toggle between Burmese and English. (NOTE: Either Ctrl+Shift OR Alt+Shift will work as toggle mode. You can set up this key combo as the way you want by pressing "Change Key Sequence" button in Input Locales
Apr 15, 2014 | Lenovo Computers & Internet
ASUS P5KPL-AM SE Motherboard(northbridge problem)help me how to fix this..give me guide plssss..
Hi, you can try to renew or upgrade the drivers from here:
http://www.asus.dk/Motherboards/Intel_Socket_775/P5KPLAM_SE/#download
Please select your operating system 32 or 64 bit.
Then select the driver for the chipset ( i guess its them you need )
and click on global for download.
When you have downloaded the files you have to unzip them
before installation.
When unziped choose the exe or installation program.
Here is a free unzip program:
http://www.7-zip.org/download.html
Just click on the exe file for download.
Also try windows update.
Hope this will help you.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I need motherboard driver for asus p4s533-x
you can download all your driver software for your Asus P4S533 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Aug 18, 2011 | ASUS P4S533-X Motherboard
Unable to initialize adlm
Unable to initialize adlm error after uninstalling Service Pack for 2014...
Solution:
There are 2 solutions available, either of them can help you to resolve the license issue.
Option #1:
Uninstall and reinstall the Service Pack (any of the Service Pack if you have more than one) that you want to keep. This will restore the mismatched file versions to the correct one.
Option #2:
Copy and replace files manually
1. Download the LicenseCrash.zip attachment below, unzip to your local drive, and then unzip the 32-bit or 64-bit package according to your platform.
2. Unzip the package
3. Close all running Autodesk products
4. Stop the FlexNet Licensing Service from the Task Manager:
  • Click Start ? Run
  • Type taskmgr and the Windows Task Manager will open.
  • In the Windows Task Manager, on the Services Tab, right-click FlexNet Licensing Service ? Stop Service.
5. Replace the following 5 files from the unzipped folder into the following locations:
a. Replace adlmact_libFNP.dll and adlmact.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
b. Replace adlmint_libFNP.dll and adlmint.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
Note: Most products put this file under the root folder of "\Program Files\Autodesk\#Product name#\" i.e. AutoCAD2014, but some other products put this file under subfolder, i.e. Inventor /Alias in \Program Files\Autodesk\#Product name#\Bin folder.
c. Confirm and if necessary replace FNPLicensingService.exe with the one in the unzipped folder to avoid file version incompatible issue.
6. Launch your products.
Mar 20, 2011 | Autodesk AutoCAD 2010
I bought a brand new Asus CG5205-AR003 W/Intel core i5 650gig/8gram. Installed PNY GeForce9800GT and running Windows 7 Home premium. Installed my old version of Pinnacle Studio 11 then upgraded to Studio...
Ok you need to UNZIP this file BEFORE you use it. Then go to the Unzipped file location, and then run the install/setup .exe. get Download, WinRAR this will uncompress/Unzip many formats.
http://download.cnet.com/WinRAR-32-bit/3000-2250_4-10007677.html
Feb 22, 2010 | Pinnacle Studio Plus Version 11
I cannot run the driver (HP officejet 9110) for window XP . I downloaded and tried to install but there was no EXE. file. I tried to unzip, too.
Most drivers for printers are just code on a note pad page, when you click on add printers, you choose the make and model and sometimes windows has the driver built into, if dosent click on have disk tab and browse to the driver you downloaded, it should pick it up and install it. If it is a zip or rar file you might have to unzip to a new folder on the desktop. if it dosent unzip then it may be a corrupt file. hope this helps.
Jan 30, 2010 | HP Officejet 9110 All-In-One InkJet...
HP LaserJet 5200 PCL 6
check where are you unzip file, and start setup from desination folder
Jun 16, 2009 | HP LaserJet 5200 Printer
I have lost my driver scanner D646U ex and i try to download from internet but it doesn't help I download from this website WWW.CANON.COM http://www.nodevice.com/driver/CanoScan_D646U_ex/get36927.html...
Hi!
Make a folder on your desktop, unzip that zipfile to that folder, connect your scanner to you pc, when windows recognize it and ask for drivers, point it to that folder where u unziped the zipfile.
Dont forget to download and install all the files on that site, like toolbox etc, you gona need them all
That should solve your problems
Good luck
Nic
Mar 11, 2009 | Canon CanoScan D646U Flatbed Scanner
Can't download driver for HP LaserJet 1005 Printer
Most likely the files have been unzipped to a TEmp folder. You can do a search for these files, or alternately, make a folder on your desktop and change the destination of unzipped files to that folder. You could also try using the 'Classic" view in WinZip..
Oct 29, 2008 | HP LaserJet 1005w Printer
I HAVE A NEW PC AND AM RUNNING WINDOWS VISTA HOW DO i INSTALL MY PHOTOSMART 2610 PRINTER? i HAVE A CD FOR WINDOWS XP sorry Didn't know caps lock was on.
Well first off, you're going to have to download the Vista drivers for the 2610 from the HP site.
Once you download them, unzip the file (just doulbe click it to unzip) and make note of where it unzipped to (it will say something like C:\drivers\xxxx
The go to your printer window.
Click the "Add printer" and local install. When it asks about drivers (what kind of printer you have) click "Have Disk" and point it at the folder the download unzipped to.
That's about it.
You don't need the install disk.
***Note***
In some cases, the download file will be a complete install routine. In that case, once you unzip it, sometimes it will go right into the install, in other instances, you have to look at the folder it unzipped to, and look for a setup.exe file
Aug 23, 2008 | HP Office Equipment & Supplies
Brother QL-500 (Bundle) Thermal Label Printer Logo
1,016 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
