Question about Maytag Neptune MAH6700A Front Load Washer
There is an intermittent chime going off and it is say SR-5 on the screen
Found the manual which says it is a control problem and machine needs to be serviced.
Posted on Feb 09, 2010
How to Eliminate annoying Intermittent Warning Chimes from a 1994 Continental Instrument Cluster?
This is the simplest & easiest fix, to make your '94 Cont. drivable, without having to listen to incessant CHIMES beeping every five minutes, due to faulty sensors and electrical glitches from the junk message system. Go under the dash, on the right side of the steering column and remove the plug (10 wires) from the 'warning chime module.' There is a tan/yellow wire in that plug on pin #7--that is the "tone generator" wire. CUT IT.!!! Now, when all of those faulty inputs try to get to the warning chime module--they CAN'T! Problem solved--no more beeping. This does not disrupt the chime from sounding if you open the door with your keys in the ignition, or with the lights still on--it continues to protects you from THAT. Remember to watch your OWN coolant & oil levels--to make sure no REAL problems exist--and you're good to go!
Dec 29, 2014 | 1994 Lincoln Continental
Stuck on safe mode screen says panic: we are hanging here...
Try switching off the machine and unplugging. Leave for 5 minutes, then plug back in and switch on, once you hear the first chime from the computer, hold down the alt+cmd+P+R keys (PRAM). Until you hear the second chimes, then let go the keys. If this doesn't work I suggest the same procedure with the switch off etc...but this time when switching back on immediately hold down the 'C' key (don't wait for chime) and start in safe mode. Once you are there reinstall the Operating System from the disk. Alternatively, if you can get to the disk utilities runs a check on the hard drive and hit "repair'.
Try this...hope it helps
Regards
Sep 30, 2014 | Apple iBook G4 Mac Notebook
Saturn Vue 07 brake system warning light stays on and chimes intermittently--EB in off position
Check the warning sensor adjustment as the eb system may be worn enough to set it off if the adjustment is too close.
Feb 15, 2014 | Cars & Trucks
Why does a chime ding intermittently, always twice?
Door open chime? Mayhem defective door switch
May 13, 2017 | 2007 GMC Envoy Denali
What is the 5 chime, cycling 5 times, then off? comes on after I start the car. Thanks, Jim
Is your airbag light on or not working? does your seatbelt light work? do you wear your seatbelt? This type of chime usually indicates a problem in the SRS system. (safety restraint system) Assuming 5 chime pause 5 chime pause and continues for 5 cycles and then stops.
Oct 17, 2009 | 1999 Ford Taurus
Drivers side door chime and light go off intermittently
The switch in the door is shorting out. I would have the door adjar switch changed.
Jul 16, 2009 | 2001 Volkswagen Jetta TDI
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
2) Set time, Date, etc:
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Maytag Neptune MAH6700A Front Load Washer Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
