Question about Targus Wireless Optical Notebook Mouse PAWM10U
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
    Scholar:
  • 59 Answers
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Posted on Feb 08, 2010
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
Cannot get mouse to move arrow
Check the dongle to see if there are any buttons on it that need to be pressed.
Apr 21, 2010 | NexxTech NWOMUMI Mouse
I changed batteries and forgot how to reconnect. It is plugged in via USB, batteries are birght. I have pressed the connect button on the base. It flashes but the mouse does not work. I have pressed the...
This is from the manual for the Logitech MX700 cordless optical mouse.
1. Press connect button on Base Station.
Its LED blinks green. 2. Press connect
button on mouse bottom. Base Station LED
turns solid green, and then off.
I hope this helps
Mar 07, 2010 | Logitech MX 700 Mouse
Receiver light is steady green. mouse won't light up. cursor won't move.
Why don't you try at the moment of placing a new battery to see if the small button that protrudes, where the receiver is located at the bottom of the mouse is pressed down. Without the receiver in place that **** on must be out for as long as the receiver is in the USB port.
Good luck!!!
Chawah.
May 19, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
CE 0560 Logiech went dead, batteries are ok, just stopped working
By now you've got your problem fixed or you've bought a new mouse, but I had the exact same thing today. I tried everything you did, then I found a crazy solution that suddenly worked. I haven't a clue know whether it'll work for anyone else, but here it is:
When "connecting" the cordless mouse to the transmission unit (ie, enabling them to work together) you go ahead and first press the "Connect" button on the transmitter first. (I'm sure everybody knows that.) But the trick for me was that when I then pushed the small white connect button on the bottom of the mouse, I finally used a ballpoint pen (retracted) to make that white button really engage. That did it for me. My finger was just too soft to make that little white button on the mouse engage properly. The second I pressed firmly with the pen, hallelujah!, it worked.
I hope that works for you. Cheers!
Feb 07, 2009 | Logitech Cordless Mouse
The receiver will not stay on
have you got the button on the mouse bottom you must press when you have pressed the one on the receiver to have them connect with each other and every time you change the battries in mouse you must repeat this proceedure.
Nov 20, 2008 | Logitech Cordless Mouse
Dell Wireless Keyboard stopped working
  • Normal 0 Press the Receiver button (and the lights will start flashing.
    Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
    If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
    Hope this helps. Bud
Nov 08, 2008 | Computers & Internet
Wireless mouse
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Oct 06, 2007 | Logitech Cordless Optical Mouse for...
The springs have come out Dell Logitech wireless mouse
springs came out. anyone have a description of how to re-assemble.
Sep 05, 2007 | Computers & Internet
Targus Wireless Optical Notebook Mouse PAWM10U Logo
807 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
