Question about HP 48gx Calculator
HP 48gx I use the 48 as a data collector for land surveying. When I take the shots it records the data correct in the sideshot, traverse screen. But when I inverse from point to point in the inverse menu, it gives me a terribly wrong azimuth and distance. Is there anything I can do to fix this problem?
If you are using the TDS software it may be in the backsight menu - try changing your angle to angle right- if not already set up that way - should work
Posted on May 12, 2008
Will a engine from a 2009 traverse fit a 2011 traverse
Probably as it is only 2 years apart. Why not buy the 2009 though?
2009 Chevrolet Traverse Engine - AutoZone
https://www.autozone.com > ... > 2009 Chevrolet Traverse Powertrain
Check The Fit.: (0). Part Number: DCVW; Notes: Long block. IMPORTANT: See Warranty Information Bulletin. The VIN# is required to ensure that the correct part is ... Check Availability and Pricing Information · 2009 Chevrolet Traverse Surefire Engine, Part Number: DCVX Vehicle Specific Surefire ...
Complete Car & Truck Engines for Chevrolet Traverse ' eBay
https://www.ebay.com > ... > Complete Car & Truck Engines for Chevrolet Traverse Results 1 - 48 of 222 - Shop from the world's largest selection and best deals for Complete Car & Truck Engines for Chevrolet Traverse. Shop with ... 2009 Chevrolet Traverse 3.6L Engine Motor 6cyl OEM 118K Miles (LKQ~172305775). There is NO .... Chevrolet Traverse 2010-2011 (3.6L, VIN D, 8th digit, opt LLT). LKQ SKU: ...
2009 CHEVROLET TRAVERSE - Engine Assembly 3.6L, VIN D, 8th ...
www.carmonkeys.com > ... > CHEVROLET > TRAVERSE > 2009 > Engine Assembly US$2,789.99 - ‎In stock
You will get an engine that is 100% interchangeable for your exact automobile. Engines are particular for a certain model, make and year of your vehicle. We make sure your engine fits this criteria. See more Frequently Asked Questions. Related products. Picture of 2009 CHEVROLET TRAVERSE - Engine Assembly 3.6L, ...
Feb 28, 2018 | Cars & Trucks
HP 48GX Says "DUP Error:
Do you have anything on the stack? The DUP function duplicates the top element of the stack. If the stack is empty then you'll get this error because the calculator can't duplicate nothing.
Aug 22, 2011 | HP 48gx Calculator
My HP 48GX just displays a black (all pixel) display screen with one vertical stripe down the middle. I tried reset button and now it displays 2 vertical stripes (the new one divides the right half in...
I just had this exact problem so I reset the memory as instructed below. Know I am back in business. Memory reset A memory reset will return the HP 48 to its factory-default state, which will erase all stored user memory. Use this feature very carefully.
  1. If necessary, turn the calculator on.
  2. Press and hold the ON+A+F keys simultaneously.
  3. Release all three keys at the same time. This should cause the calculator to display the message "Try to recover memory?"
  4. Press the A key to attempt to recover memory or the F key to erase the user memory. When A is pressed, occasionally the objects in memory are recovered in new sub-directories of HOME labeled D.01, D.02, et cetera, although there is no guarantee that all of the variables will be recovered. Pressing the F key will cause all information stored by the user to be erased from calculator memory. This will also affect any RAM card that is merged with main memory. If the card is not merged or it is write-protected, it will not be affected by this reset.
Hardware symptoms and solutions I. The display screen has a blue/purple blotch of color, even when the unit is off The screen is damaged, and the calculator requires service. Please contact HP . II. All of the pixels on the screen are lit (blue)
  1. Try to adjust the contrast by holding down the ON key and repeatedly pressing the [ - ] key.
  2. If the screen is still dark, try to halt the system using the keyboard.
  3. If this does not correct the problem, try to reset the system using the reset hole with the batteries removed.
  4. If this does not work, remove the batteries and let the unit sit for 48 hours. After 48 hours, replace the batteries. If the problem persists, attempt a memory reset. Although removing the batteries for 48 hours should erase the user memory, performing a memory reset will ensure that the calculator is reset to its factory defaults.
  5. If the problem persists, the unit requires service. Please contact HP .
Dec 30, 2010 | HP 48gx Calculator
HP 48gx Calculator seems to turn on but display does not show
It might be too dim.
Turn calculator ON. Then press the ON button and hold pressure. Press the PLUS + repeatedly until screen darkens.
Nov 17, 2010 | HP 48gx Calculator
I would like to buy another programme module topographic Topo 1 and Topo 2 for my calculature HP 48 SX giorgiombr@yahoo.it ...
Here is the link to a web site where you can find resources for the HP48GX ( apparently your calculator is an HP 48SX).
On this other site you can view surveying software for the HP 48GX that is still available for sale.
Aug 14, 2010 | HP 48gx Calculator
My HP 48GX with COGO Card is running slow.
You should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Nov 12, 2008 | HP 48gx Calculator
Rs 232 port in the HP 48GX
Try http://www.fixthatcalc.com/. A friend of a friend sent his HP 48 in for repairs. You may want to check into them.
Sep 22, 2008 | HP 48gx Calculator
HP 48gx Calculator Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
