Question about Nakajima Office Equipment & Supplies
When turned on it moves 4 spaces to the right stops and beeps constantly
    Genius:
  • 1,218 Answers
Sounds like the multi-strand cable that comes out of the carriage assembly may have 1 or more broken wires... check and inch or two from the carriage itself.... if broken they can't be joined again( and work reliably)... the carriage unit would have to be replaced.
Posted on Aug 28, 2010
F&p E331T constant beep
The ActiveSmart system that manages the fridge will beep when there is fault, and the amount of beeps will indicate the fault code.
To understand the fault code, a technician would also need to know the version of activesmart, and the product ID on the grey label on the bottom right of the fridge.
Dec 02, 2016 | Refrigerators
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
Constant beeping when turned
The freewheel lever isn't re-engaged properly. Try moving the lever to "free" then back to "drive" again. The lever moves a small micro-switch.
Apr 02, 2014 | Electric Mobility Health & Beauty
It turns on but keeps beeping
The constant beep means that the channel you are on is not programmed. Try moving the channel knob to other channels. If it stops beeping, you are on a channel that is programmed. It is possible that none of the channels are programmed though.
Take it to a motorola dealer and they can program it for you.
Jul 15, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Carriage all the way to the left, constant beeping sound
The Mastertype 3 is the same machine as the Nakajima AE-710.
Check that the Print wheel is installed correctly.
Check the multi-wire flex harness underneath the carriage assembly...there may be broken wires.
Feb 09, 2010 | Olympia Mastertype 3 Typewriter
Wheelwriter 5 --cant set the right margin
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Dec 07, 2008 | IBM Wheelwriter 30 Typewriter
Kia brake beeping
brake pad warning light pads need changed
Aug 17, 2008 | 2002 Kia Sedona
Margins
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
Aug 10, 2008 | Brother EM-530 Typewriter
Margin locked
check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Jan 28, 2008 | Swintec 7040 Typewriter
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
