Question about Canon PIXMA MP150 All-In-One InkJet Printer
We have this printer/scanner and have moved several times and can not find the cd to install it on our computer. What can we do to install this printer?
  • 129 Answers
Here the link to download the drivers
http://www.soft82.com/download/windows/canon-pixma-mp150-all-in-one-driver/
Posted on Feb 08, 2010
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Machine suddenly stopped scanning
Open My Computer and see if there is a scanner device at the end of the list. If there is, try to scan using Windows scanner and camera wizard. (right click on it, Get picture using Scanner wizard)
Remove the drivers from Control Panel, Add remove programs. Disconnect the printer. Restart the computer. Reinstall the drivers from the original CD that came with the printer. When the installation program ask you to connect the printer, do so. If you have lost your CD, try to download the "Full installation package" from the site of the manufacturer.
Aug 01, 2010 | HP OfficeJet J4580 All-In-One Laser...
Getting a scanner error have tried several times and cannot get it to clear it will print from computer but will not scan My printer/scanner is an HP Photosmart 4700 but could not find on list
your need to install the driver from you cd/dvd driver which is included when you purchase it. try to reinstall driver, much better install anything what drivers available from your cd/dvd driver. connect all cables, the power cable and the usb from your scanner to computer, then restart the computer and try to scan.
Mar 22, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Hp PSC2355 scan function inop
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq9
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
After running full system recovery I tried to reinstall my printer and scanner. I reinstalled my printer (HP Deskjet 870ces). Then tried to reinstall HP Scanjet 5100c on a machine running Windows XP Pro....
Some time printers and scanners conflict. Try this, uninstall both printer and the scanner, then install the scanner first and try it to see if it works. Then install your printer. If it doesn't work let me know I'll walk you through. Good luck :)
Feb 21, 2009 | HP Office Equipment & Supplies
Photo smart 2610 all in one scanner will not scan
hey i also had this type of problem. but i solved it and hope it will solve yours too.
first of all uninstall all ur hp drivers and softwares related to the hp printer. then restart your pc. now disconnect ur printer with ur computer and turn it off and again on after 15 secs.
now insert the cd which i have got with the hp printer in the cd-driver of ur pc and install the driver.
after the installation is complete, connect ur printer, but do not remove ur cd.
then start scanning, and if it will again ask for installing driver, u dont have to worry it will install it from the cd.
this would surely help u, if problem persists, please tell me.
Jan 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
I have a lexmark X2690 printer/scanner with the disc--both inks are in place--I have installed-uninstall several times--I am using a usb port--I have windows vista-acer c0mputer--when I last installed...
hi T-staples.
did you check to see if the drivers are installed?
if you need the drivers try this link out.
LEXMARK Scanner Drivers For Windows
or this one.
support lexmark com
or .
Make Your Selection
or.
Using the CD that comes with your printer www.lexmark.com.
  • On the home page, navigate through the menu selection, and then click Drivers & Downloads.
  • Select the printer and the printer driver for your operating system.
  • Follow the instructions on the screen to download the driver and install the printer software.
  • Dec 17, 2017 | Office Equipment & Supplies
    SOFTWARE MALFUNCTION NO DIRECTOR OR SOLUTION CENTER
    What Operating system are you using? One thing I would recommend trying is uninstalling all software related to the printer/scanner, then turn off the computer and unplug the printer from the computer. Turn the computer back on then restart the computer and try reinstalling. Your problem could be that the computer is not uninstalling the printer/scanner all the way meaning the computer is still detecting the printer/scanner. Those steps would fix it if that is the case.
    Oct 22, 2007 | HP PSC 1410v All-in-One Printer
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    old marine
    old marine
