Question about Bosch Drills
Hi, I have a Bosch PSB24 VE2 cordless drill which has started overheating with an acompanying 'hot' smell. Occasionally the drill labours and then picks up speed. Also there is quite an 'impact knock' as the drill speeds up. I have dismantled the drill, removed the gearbox but the motor still gets hot and also still has the knock ( can't recall if it always made this noise ) but certainly much hotter than usual. Brushes have plenty of life left but the motor is quite tight to turn by hand. Any suggestions would be graefully received. Thanks
    President:
  • 986 Answers
Replace your brushes,That should fix your problem, you must have used it alot.I hope this help you, sometimes they will send you a new set when you bought it
Posted on Feb 08, 2010
Drill completely stopped working. Bad smell from battery. Charged up the second battery and plugged it in. In three seconds, it started smoking very badly. I removed it. The drill worked with second...
The only way to tell if you can fix it is to take the drill apart...
Look for two wires melted together...my guess is that they got too hot and melted together inside the drill... separate and insulate and you should be fine...
heatman101
May 21, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
When I was useing it to put in a long lag bolt,it starting slowing down at the vary end,finally it got hot and I heard a loud popping noise and the handle part of the drill got hot and smoked a little...
The drive motor and/or battery pack overheated and blew open a circuit. The only "repair" would be to replace which part(s) failed or replace the entire tool.
John
Dec 09, 2010 | Makita 18V Cordless 12 In DriverDrill Kit...
My hammer drill got overheated
Hello. If the gun has cooled down and still will not start up then the gun will have to go into a Bosch service center for a repair. Here is the owner manual with the pertinent info
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00018v-1.pdf
please rate my answer as very helpful. thanks.. Joe
Apr 26, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Bosch drill dosent work even when i charged it only used about three times
Hi , try and find proof of purchase ( receipt/credit card statement ) and contact your local Bosch service centre ,in most cases it will be repaired under warranty .
Hope this helps
Mar 12, 2010 | Bosch 13624 24V Cordless Hammer Drills
My cordless drill smells when it is being ran. Is
could have trash in motor. clean motor with compressed air.
Jan 10, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
My cordless drill PSB24VE2 made a clunking noise on start up, but still seemed to work OK, then it worked but slowed right down. It now doesn't work at all. If I depress the trigger it give off a strange...
you need to have it check out. sounds like your motor, the smell my be the motor over heating. Don't try and use the unit, may damage it more . good luck
Oct 23, 2009 | Bosch Drills
Kawasaki 840079 Green 19.2 Volt Cordless Drill Just stop working
It is possible that you overloaded it in high range and maybe stalled it out. Usually when the motor burns it is from overloading/overheating. If this is a newer tool I would try and take it back for warranty repair and not say anything about the smell. Its worth a try, some of the motors for the cordless tools are around 50-60 dollars
Mar 11, 2009 | kawasaki 840079 Green 19.2 Volt Cordless...
Just stoped working
make sure that in the speed selector you are fully on speed 1,2,or 3...sometimes you can fall inbetween and then it will do that...otherwise you may have overheated the drill and will need to deal with Grainger or another auth. Bosch dealer for warranty...if they don't fix you, buy a Hilti
Mar 02, 2009 | Bosch 13624 24V Cordless Hammer Drills
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Drills Logo
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
