Question about HP OfficeJet 7110 All-In-One Thermal Printer
I haven't used my pinter for a couple of years. The system now says my prinre head for the mejenter are bad and the printer is only producing blank sheets as it prints.
  • frannlee Feb 08, 2010
    Mr. Smith, are you suggesting that I do not need new printer heads even though the system is saying that the heads are bad?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This can be caused by a number of things:
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse. Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer from the printer's control panel menu—
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
To check if it’s fuser just put a sheet of paper in the manual feeder in the front of the ETB drawer. Print a configuration page and when the back edge of the paper reaches the bottom of the feeder, open the back of the printer to stop the printing. Now open the ETB drawer and look at the unused sheet and see if the defects are present. If they are it is not the fuser. If the defects are gone, then it is the fuser.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    No I am not saying that. If I have been at your place the first thing I would have tried was to clean the Print Heads. To clean the print head
    take a hot water towel with the printer unplugged and the cartridges out, clean
    it till the time you see there is no ink residue on the towel. If still it wont work then its always better to buy a new printer as replacing the Print Heads will cost you more then the price of a new printer.
    Thanks
    Rylee
THE PRINTER PRINTS BLANK PAGES
If you haven't used your printer in a while, it's possible the print heads have become totally clogged (assuming you haven't already checked out the obvious things like ink levels etc.)
I found that by removing the printhead (remove the ink carts, flip a lever and lift out) you can try spraying some window cleaner onto the nozzles on the underside, leaving a few minutes, and then get a bowl of hot tap water and touch the nozzles on the surface of the hot water.
This will definitely help some 'soft' blocked nozzles. If you get SOME print action after this, then you know the problem is definitely clogged nozzles. However, if they're severely blocked, then you can find a print head cleaner kit online for about $10. It contains some cleaner fluid, a syringe and some pieces of clear hose that fit on the ink funnels on top. Then you can inject cleaning fluid into the nozzles. Did it for mine - worked a treat!
BTW, the inkjet head is fairly watertight in itself - you can flush the nozzles under a hot tap no problem. DO MAKE SURE THE HEAD IS COMPLETELY DRY BEFORE YOU PUT IT BACK IN YOUR PRINTER!
Jun 28, 2012 | Canon PIXMA iP4600 Color InkJet Photo...
HP 4700 keeps running out of black after a couple of days
cheak by printing s test copy and make sure their in the pinter rigght
Apr 05, 2012 | Office Equipment & Supplies
After cleaning/maintenance, pages are still blank.
If you have just bought new carts (ink) and installed them into the printer and there is blank pages. and the printer is acting like its printing (moving from left to right) and sending paper out then i would say 99.9% it is defintally the head. On the printers that have the head built in and you insert your carts (ink) into the head and you don't print but very so often this is a common problem with ink printers the head gets clogged. If you are attached to your pinter you can take it to a print shop and have them clean the head (they have to remove it from the printer)
When buy a printer if you dont print alot i always suggust to get a printer where the head is built into the cart (ink) like hp they are more expensive to repalce the ink but you get a new head every time :)
Hope this helps
Steven.
Apr 21, 2010 | Canon PIXMA MP130 All-In-One InkJet...
A couple years ago I came home from deployment and my printer would only print blank pages. I replaced the ink catridges and did the nozzel and head cleaning steps etc.... Still blank pages. Am at a loss...
Okay, let's start with a real basic question. Do you have the correct printer driver for the operating system you are using?
For example, a printer that has a driver for Windows XP my not have a driver for Vista.
If the vendor does not have a matching driver, then they have more than likely abandoned any further product development for that model.
Don
Nov 12, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Pinter not printing or scanning
call 1.800.421.6699 and select option 01 for prints missing black or color ink
Jan 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson Stylus CX4700
Hi , in epson product are good the problem is the head are easily clug by ink , the pinter need to check nozzle it can be determine the head need to clean printing result of check nozzle , if the result blank or small printing result , the head need to clean thoroughly it may consume 1/2 of the full tank ink , until the printing will clear and bold letters black and color.
Feb 19, 2008 | Canon CLC 1150 Color Copier
Pixma ip1500 Canon-
the printhead may be bad. if it has set for sometime without being use the head will clog.
Dec 28, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Jun 21, 2006 | Epson Stylus 680 InkJet Color Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
