Question about GE Dishwashers
Dishwasher faulty I have a ge dishwasher model ghd6310l15ss. Half way through the wash cycle the water stopped coming into the machine. The float seems to be working fine. Any ideas?
  • kazziebing Feb 08, 2010
    We turned the machine off and now it appears to be working. The float was not stuck. This happened before - the water stopped coming in to the machine and then all worked fine after we turned the machine off and on again.
    Last time, there was no water in the machine at all and we could smell the element overheating.
    did you get my last email?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that the float switch is about to go bad as switching it off and then turning the dishwasher back on is resetting it. The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Also, if there's no water entering your dishwasher, you’ll need to check the Water Inlet valve. The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 09, 2010
    Brigadier General:
  • 3,917 Answers
Make sure that the float device is not stuck in the up position and if it is, wiggle it and make sure it's seated in the down position or else it will think the unit is already full of water. If its fine then check the voltage to the electronic water valve and see if it's getting voltage or not. If it is, then replace the electronic water valve.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 08, 2010
GE dishwasher model number GHDA480N10WW doesn't fill with water.
check the float switch usually located in the front right of the dishwasher it should move up and down freely sometimes crud will get under the float and hold it up so the dishwasher thinks its already full.
Nov 02, 2013 | Dishwashers
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
I have a Bosch Exxcel dishwasher which runs the drain pump constantly even with the door open and despite there being now water in the machine at the cycle wont start. I have checked the warer amtrix and...
I am not sure about this model but most models run a drain cycle for a set period at the start of a wash cycle and then move on to normal filling and cycle of machine provided the various switches are at the low level it will carry on to its set cycle,is the apartment or flood switch ok?
Jun 30, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
All the lights come on but the machine does not wash
The problem could be 1) The inlet solinoid in line with the main water inlet faulty this acts as an electrical tap controling the inlet water. 2) The triggering of the anti flood system (polysireene float and micro switch at the base of washer) due to water leak / spill (this device causes the washer to stop until the leak is cleared.3) Water pressure to low.
Jun 01, 2010 | Baumatic 23 in. BDW5 Built-in Dishwasher
I'm trying to get my GE GSD1200G00WW to work. When it is put on the wash cycle, I can hear the pump running but the tub does not fill with water. I checked the float and it seems fine. Water valve...
Confirm 120V across the water valve terminals in a couple of minutes into a wash or rinse cycle. (when you turn it on at the beginning of the wash cycle it will drain first, and then will energize the water valve to fill up.)
If there is 120V across the terminals - it may have:
  1. faulty solenoid coil - check for continuity, replace valve if none
  2. clogged filter or nozzle inside the valve. Try cleaning the filter, replace valve if it didn't help
Apr 16, 2010 | GE GSD1000 Dishwasher
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
Does not appear to have enough water in the dishwasher
The water should come up about an inch or so below the sill of the machine. It is governed by a float switch, not the timer. The float is located near the front of the inside of the machine. Clean it up and make sure it moves freely. If probably is stuck. It governs the height of the water.
Dec 09, 2007 | GE GLD5850LC Dishwasher
GE Trition Dishwasher Leak
There should be a screw on the top center where the door latch engages. You can just loosen it with a screwdriver and slide it back and re-tighten. If this doesn't solve the problem, it may be a problem with the water level float assembly. Go to the GE website to look up your model.
You may be getting too much water in the tub. The float assembly signals the system to stop adding more water. If this gets obstructed, the valve will continue to add water. Start a cycle and wait to hear when the water valve closes. Carefully open the door to see how much water is in the tub. It should not be up to the door. If it is clean up the float. Let me know how you made out or if you need more help.
 I know how it is when a dishwasher breaks down. I've had my share of water damage. Not to mention the pain of washing dishes by hand.(We're so spoiled. I'm guilty as well.)
Regards,
John
Oct 16, 2007 | Dishwashers
Dishwashers Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
