Question about Cell Phones
The ring tone on our FS 900 Freedom Phone is too loud. We already tried the HI/LO control on the side of the phone without success. What do you suggest?
  • purch174 Feb 08, 2010
    We also tried unplugging and plugging the phone back in without success. There is no reset button or switch on the phone.
  • Cell Phones Master
  • 6,993 Answers
I would suggest that you wait for a call to come in and while the phone rings, you can press the Hi/Lo control and see if it will respond this time.
Also try to do some study on the phone and check all the settings on the phone, you should be able to come across a solution.
Has the ring tone been loud ever since you have been using the phone?
Best regards
Posted on Feb 08, 2010
    President:
  • 1,871 Answers
Hello:
Just look around the phone for a button [reset or resetting] . Just press it and problem will be solved .
good luck
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
My Nokia 6085h will not ring out loud.
there should be a volue control in the phone section of the setup icon turn that up
then if you didnt assign a ring to your groups, try asigning a different ring tone to each group and make sure the ring tones have a loud sound by playing them using the phone.
other than that, it shoud be a hardware problem with the speaker that needs to be replaced.
Dec 29, 2008 | Cell Phones
Message alert tone
hi there ,
             you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps..
Simon
Sep 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Pebble ringer inop
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
Mar 20, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Unable to dial out, check voice mail and see call display
Hi at the back of the phone you will see a selectable Hi/Lo/Off switch. Slide the (Ringer) switch to High position or Low position to turn the ringer on. Hi for high volume Lo for low volume.
To prevent hearing any ringing of incoming calls slide the (ringer) switch to the off position but when you ready to accept incoming calls again remember to slide the switch back to either Hi or Low setting. Hope this made sense and helped.
Oct 24, 2007 | Curtis Trimline TID582 Corded Phone
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
