Question about Pioneer DVR-112D DVD RW Dual Layer Burner
CD/DVD Writer drive not detected
Hardware detected under device manager and when we troubleshoot it says the best drivers for this product are installed but when we want to use the CD/DVD writer we cannot locate the drive.
  • 4 more comments
  • Vallidack Feb 23, 2008
    Drive F
  • Vallidack Feb 26, 2008
    Even with disk in the drive we cannot access it.
    The drive is definitely F. E is the CD drive, D is the system and F the DVD
  • Comatosecv8 May 17, 2008
    I've tried replacing the IDE cable and reinstalling drivers. uninstalling drivers. re-booting without it connected. rebooting now connected.. reinstalling drivers... still no good. These drives are ****. I'm about to try updating firmware as it would seem pioneer has released many versions for this drive as they had trouble getting it right. probably a stupid vista thing. bl00dy microshaft
    its a Pioneer DVR-112D(BK) from a brand new Leader computer.
  • rdakota Sep 23, 2008
    When I run windows Vista64 it does not detect the drive but when I run leopard everything is oké
  • Anonymous Dec 05, 2008
    Genius:
  • 1,019 Answers
is it showing As Drive D:- Or E:- In My Computer ?
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 1 more comment
  • Mike Waldron Feb 23, 2008
    Ok well thats a start.
    It,s showing on the PC, Right click on the drive with a disk in it, and at the bottom properties. or open-explore.
    it should give you more info.
    mike @ Compurepair.
  • Mike Waldron Feb 26, 2008
    At least you located the Drive, which was your initial request.
    I,d suggest making another post, regarding ** Unable To Access The Drive**
    Mike @ Compurepair.
  • Mike Waldron Feb 27, 2008
    I,ve finished with this Post.
    Perhaps your Disk Has Faults/Errors On It. Maybe A weak Laser Not reading Disks. Dust On The Laser Pick-Up ?
    Fault On the IDE Ribbon Cable, Device not set correctly On Jumpers Master/Slave.
    What do you want, me to come And set it up for you ??
    Mike @ Compurepair.
    ** All advice given on this Site By Myself Is Free**
Hp dvd writer dvd200i
since you have not stated what the problem with your dvd writer is i will have to guess
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 17, 2011 | HP DVD Writer Dvd200i (AA622A) DVD+RW...
My HP DVD1040r writer that came with my Dell dimnension B110 won't burn CD or DVD's. I did a fresh install of XP Pro SP3. I need the installation setup Cd that came with the drive, but I don't have it. HP...
hi.. click on my computer.. properties.. hardware.. device manager.. select CD/DVD Rom.. (it would be in a Yellow Exclamation Mark).. doubleclick on it.. then select the option that says.. Driver Details.. and then Update Driver.. try to select options detect the driver online.. it will automatically detect the driver and try to search for it online..
or use the Product number of ur HP comp.. i.e., the one ending with #ABA.. go to www.support.hp.com.. and enter the numbers before the # sign.. and search for Drivers CD/DVD Rom..
May 04, 2010 | HP LightScribe dvd640i (DVD640I)...
Had to roll back my computer now i cant find the install disc for my hp 940d dvd need the nero and light scribe disc any info would help
If the DVD-writer was factory-installed, then you can contact HP, and order a replacement CD that will contain the NERO and LightScribe software.
Cost will be under $20 for the CD, and about $20 for courier-delivery.
Or, instead of NERO, access http://www.MajorGeeks.com
and download "Ashampoo Burning Edition 6". It is _free_ software.
Version 9 of the software is better, but it's not free.
I don't have any substitutes for the LightScribe software.
Nov 23, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
Working only with CD, but can not start any DVD
open your device manager , off a right click from ,,, my computer . click properties , hardware tab , then un-install both the cd and dvd . re-start your system and let windows detect the new hardware and re-install it for you . Let me know if this works .... if not we can troubleshoot further.
good luck
May 24, 2009 | BenQ CB523C CD-RW/DVD-ROM Combo Drive
My dvd/cd rom is not opening, checked hardware, not even listed
just check your dvd writer is open or not open because the some time not open the dvd driver then not detect
fist of all remove the dvd rom and reinstall because the some time remove the dvd drive and after reboot the laptop and check ..............ok
Apr 08, 2009 | Computers & Internet
Acer Travel mate 3240 dvd reader/writer
you can clean your dvd drive
i would also check my computer right click drive then properties
check that settings are correct for
autoplay
hardware
and recording
if you still have the problem then device manager and update driver
please let me know if problem persists
don't forget to rate
Feb 09, 2009 | Acer 290LMI PC Notebook
LG GH22 dvd writer - not reading
I had the same problem with the GH22 Internal drive on vista. Assuming this is the only cd drive you have, just go to the device manager and remove/uninstall anything under "DVD/CD Rom Drives" then restart. It should get picked up and recognized properly. It took a couple of restarts to work. For refrence, I only have the LG GH22NP20 installed, what appears in device manager are 2 items... (1)HL-DT-ST DVD-RAM GH22NP20 SCSI CdRom Device... (2) KU1051Q EAG855E SCSI CdRom Device... Incase you have multiple cd drives, this should help tell em appart. Enjoy. IDK399
Jan 20, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
DVD DRIVE/CD-WRITER
GO TO CONTROL PANNEL
SYSTEMS
HARDWARE
DEVICE MANAGER
CLICK DEVICE MANAGER(WINDOW)
EXPAND CD /DVD ROM DRIVES
RIGHT CLICK ON SELECTED DVD/CD DRIVE
SELECT PROPERTIES
1.SELCT DRIVER ( CLICK UPDATE DRIVER)
2.CHECK DVD REGION CODE.
3.UN-INSTALL DRIVER
4. REINSTALL DRIVER AGAIN(AFTER STEP 3)
OR
IN DEVICE MANAGER RIGHT CLIVK DVDCD ROM DRIVE
UN-INSTALL DRIVER
OK
REBOOT COMPUTER
ADD HARDWARE(CONTROL PANNEL)
IT WILL PROPMPT FOR INSTALLATION OF DRIVER
SAY OK.
PROCEED WITH WINDOW INSTRUCTIONS
DVD/CD ROM DRIVER WILL GET INSTALLED AFRESH.
HOPE IT WORKS.
Jul 01, 2008 | Computers & Internet
About my dvd writer
The issue can be either with the Hardware or the software.
Make sure that this issue happens wiht all the CDs or DVDs you are using or able to used eariler.
First, check if the DVD Drive is listed in My Computer or not.
If yes, try uninstalling the DVD Drive from the Device manager by following the steps :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Now click on the [+] mark next to DVD/CD Rom Drives to expand the tree.
Right click on the DVD Drive entry and select Uninstall.
Confirm if you get any message and close the Device Manager and restart the Notebook so that the DVD Drive Drivers will be reinstalled automatically.
Uninstalling DVD Drive Drivers in Vista :
Click on the Start Menu and type in Device Manager in the search field.
Click on the Device Manager from the results which will open the Device manager window.
Follow the same instructions to uinstall it.
If you find the yellow ! marks in the Device Manager, you may have to do some modifications in the Registry by following the instructions in the links below :
For XP :
http://support.microsoft.com/kb/314060
For Vista :
http://support.microsoft.com/kb/929461/en-us
you may have either the Upper or Lower filter or both.
Delete both of them and restart the Notebook.
Finally, try removing and reseating the DVD Drive from the instructions available in the Manual in page number 135 of 310 :
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
If the issue repeats, issue can be with Hardware.
Jun 25, 2008 | HP Pavilion dv2000t Notebook
My LG CD Writer ejects automatically without any operations...
This is normally as sign that the writer is faulty, especially if ejecting on your pc's start up. Just go through this first to check if it's just a driver fault. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Apr 02, 2007 | LG GMA-4020B Super-Multi...
Pioneer DVR-112D DVD RW Dual Layer Burner Logo
323 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
