Question about Dual XDM6825 CD/MP3/WMA Player
Dual SCM6825 Face Plate was stolen
Where can I get a replacement faceplate for my DUAL SCM6825.
I've seen XDM6820's on e-bay, and other places, but I don't think they interchange.
    Problem Solver:
  • 11 Answers
If you see spare parts for the EXACT model number as yours on ebay or ect. They more than likely interchange.
Posted on Feb 23, 2008
I am looking for a face plate XDM6820 for a car radio.
  1. so who knows what kinda malware this site is spewing.
  2. But if ya still looking for a xdm6820 faceplate I recently aquired one in auction
  3. You still got the deck?
  4. july 06 2014 today is 3 18 2015
  5. Dallas Tx area
Jul 06, 2014 | Dual Audio Players & Recorders
How do you detach the face plate on a dual xd 7600 audio and how do u use the iplug?
tab at bottom of faceplate is visible when open in the middle of face push in carefully and pull down. supposed to be able to plug into it and comes up on screen.
Aug 17, 2010 | Dual XD7600 CD Player
The faceplate for my Dual XDM6825 Car CD Player was stolen out of my car. I've searched for replacements on Ebay and Amazon, and well as extensive searches through various search engines. Nothing is...
hi i am afraid so, the reason you are not able to find one is because of theft, if someone was to steal your system from your vehicle, and just go buy a new head for the system it would be pointless being able to remove the faceplate's in the first place, i think the only way you might find one will be if someone has got a broken chassis but has a good faceplate, sorry but that is probably the only reason why you cant find one...hope this helps
Apr 13, 2010 | Dual XDM6825 CD/MP3/WMA Player
Missing face plate
What part is missing? Is it just the faceplate, or the gear mechanism as well?
I have one of these that the ribbon cable is bad and can't seem to find a replacement. I am debating just buying a new stereo. If i do, I could sell you the faceplate. email me at rad73082 (at) yahoo
Sep 12, 2009 | Dual XDMR-7700 CD Player
I just bought a Dual XDM6820 and installed it myself into my 2000 Toyota Rav4. The unit worked great for two days. Then I went on a road trip and the unit blew a fuse. I replaced the stereo fuse and the...
If the cd's come in and out fine then it has something to do with key wire (red) . I try and always use and a adaptor harness when installing aftermarket decks. Make sure your wires are well inulated and not pinched when deck is "in its place".
Jul 21, 2009 | Dual XD7600 CD Player
CD will not eject from Dual XDM6820 in-dash CD player
you are probably better off just replacing the deck. there is a plastic piece in the dvd mech that breaks and can only be repaired by sending it to dual to be repaired.
Jun 12, 2009 | Dual XDM-6820 CD Player
My dual xdm6820 doesnt turn on and theres a red binking light behind the face plate next to the reset button
Probably you are mising 1 voltage,check this you need to have 2 voltages ok,1 voltage has to be present on the yellow wire(constant voltage,means all the time,ok) and the second voltage on the red wire (this voltage has to be switched wiht the ignition key)check this and try to fix the problem,probably there is a fuse blown,you can use a tester light to check the 2 voltages.or if you dont want to do this just conect the yellow and red wires together and the unit has to turn on.
Mar 24, 2009 | Dual XDM-6820 CD Player
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull faceplate down and away from unit
to remove. To install, insert left side faceplate first, then push
right side to secure.
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Car Audio & Video Logo
132 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
