Question about Xerox Phaser 8400 Laser Printer
08,007.41:8472 It's a phaser 8400 i have no idea what to do..What could it be?
    President:
  • 2,072 Answers
Your print head wiper blade is not moving properly.
The clutch that moves the wiper may be failing.
That blade is located between the drum and print head.
Printhead Wiper Alignment: Rotate the left and right idler gears until the Wiper is all the way to the bottom and the gears cannot be rotated further. Rotating the left and right gears together ensures that the wiper stays parallel and does not pop out of the belts. Now rotate the left idler gear a couple of teeth to raise the left side of the wiper to the top. Make sure that the left side of the wiper is a bit higher than the right side. Might have to try this procedure a couple of times, a couple of teeth at a time, to properly align the wiper.
Posted on Feb 11, 2010
Testimonial: "You helped me big TIME with this annoying problem. Thank you very, very much! "
  • Rick Kasper Feb 12, 2010
    Glad to have been able to help;
Xerox Phaser 8400 prints pdfs in half page
I've seen this issue on some of my other Xerox machines (not the 8400 specifically). 9 times out of 10 the solution is to update both the printer driver to the newest version, as well as updating Adobe Reader to the newest version.
Here are the links to each:
Xerox Phaser Drivers
Adobe Reader
May 04, 2011 | Xerox Phaser 8400 Laser Printer
Can you please tell me how to print double sided? Thanks
Xerox Phaser 8400 does not support double sided prints. You have to have a Duplex Unit for Phaser 8400 part number 097S03177 to be able to print double sided. If you have the duplex unit, on the Print dialog box just click Preferences and under 2-Sided Printing select 2-Sided Print then Apply.
Nov 16, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Front Cover Open
Yes, there is an OPEN/CLOSE sensor that is sending wrong "status" information to the printer.
Jun 01, 2010 | Xerox Phaser 8400 Laser Printer
Error in xerox phaser 8400
37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing
the expected power from the supply.
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
clear.gif UNITED DATA TECHNOLOGIES INC
8825 NW 21ST TERRACE
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
clear.gif MONARCH ELECTRONICS INC
SUITE 319
1440 79TH STREET CAUSEWAY
NORTH BAY VILLAGE, FL 33141
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
clear.gif LASER PRINTER SOLUTION / FIX A FAX CORP
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
SUITE 130
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
clear.gif ADVANCED BUSINESS COMPUTERS
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
PHASER 8400
There is an encoder on the drum drive motor that picks up lubricant from the maintenance kit. It may simply need cleaned, if cleaning doesnt work, it will need to be replaced.
Xerox has parts lists on the xerox.com site for that product if you need to locate it.
Sep 09, 2008 | Xerox Phaser 8400 Laser Printer
PHASER 8400
1, The NVRam memory is corrupted.
2, A jet heater is not working
3. the electronics module is bad.
Parts possibly bad are the NVM, the Print Head or the Electronics module.
Hard without a manual to determine, all are expensive.
May 30, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
216 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
