Question about Canon i80 InkJet Printer
Colour Ink Tank error
I'm getting an error message saying that the colour ink tank is not installed. I have replaced both tanks (with new) a couple of times and have replace the printer head assembly. Any ideas how to proceed? Thanks
  • 4 more comments
  • aaronronnie Feb 23, 2008
    I have the same error 'saying colour ink cartridge not installed' but have also purchased original canon cartridges and does not seem to recognise the ink tank even though its there! The small microswitch is being pushed down so can only assume its some sort of error message in its chip or something. Have messed around trying to reset it but with no luck - can anyone please help as its a nice printer! thanks
  • Petur Feb 27, 2008
    Yes , I have the same problem, is there anyway to turn of the colour print option so that it will print only in black ????
  • selfstarter Apr 16, 2008
    i'm having the same problem with an ip90.
    it happened about a month ago and i played around with the switch with the tip of a pocket knife, and eventually it (somehow) worked.
    then i didn't use printer for a couple of weeks, went to print something today, and... same error back again.
    the fact that i got it to work once led me to believe it was a physical problem with the switch / sensor / connection, but... perhaps it's not?
  • Anonymous May 13, 2008
    Same problem. Replaced the color cartridge and get the message that the color ink tank is not installed. Can't do anything - clean, test print, align, nothing.
  • mijs Aug 29, 2008
    same problem here!
    "colour ink tank is not installed"...???
    it used to work just fine but now it's not.
    Isn't there anyone who know how to solve this?
  • daduke May 10, 2009
    I have the same problem. I have replaced the color ink cartridge and it continues to display the error message "error number: 64 the following ink tank is not installed - color" Very frustrating! Can anyone help?
    Problem Solver:
  • 10 Answers
I have the same problem, so far no solution found.
Still searching, it is not the microswitch and it is not the printhead, some board assy i think.
Suggestion from Canon: send it in for repair, $100 !
Posted on Mar 13, 2008
Yellow is printing dark muddy colour, tank content same colour.
Has the printer printed a good yellow using this ink tank at all?
Dec 12, 2013 | Brother Office Equipment & Supplies
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
Error of tank colour
Ink tank
replacement
When an ink tank becomes empty. ("No ink error"
displayed on the monitor or on the machine LCD, or
short flashing of an ink tank LED)
reset butten 1 min.
Oct 09, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon IP5200 printer - "duplicate ink tanks"
Hi i have Ip 5200 but the pawer lamp and yelow lamp are blink
Mar 26, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon Pixma MP500
When installing or replacing an ink tank, only one of the ink tanks should be installed. If the ink tank is not installed correctly, an error message will display.Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
Give a thorough check up to confirm any colour ink is not twice loaded (cannot be loaded in a single slot,may be in another slot )
May be any defective ink cartridges
Mar 13, 2008 | Canon Pixma MP500 All-In-One InkJet...
IP4200 duplicate ink tanks.
Hello there scubadave,
I've gotten in touch with Canon and have somethinga little different to try. At the very least the error should change.(Sorry, gallows humor). Please read this entire response before takingaction.
After the upcoming test procedure, I have included alink and procedure to contact Canon tech support. The assure me theywill replace any faulty tanks.
The purpose of this exercise iseither rule out ink tanks that are behaving or isolate the one(s)responsible for the dupliucate error. You should write down the results of thistest. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3.Confirm whether the printer recognizes the installed tank properly. Ifit does, it will indicate it does not detect the other ink tanks, asthey are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5.If the printer at any time indicates two of the same ink tanks areinstalled, the cause will be the last tank installed. For example, ifyou inserted an ink tank earlier, and you later inserted another inktank, and it said two of the same inks were installed, the cause of theissue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error- Duplicate Ink tank problem on my Canon PIXMA iP4200
<Describe how error occurs>
I have replaced the <color in> question> tank, reseated it, yet the error continues.
Youwill also need to list what inks are being used in the printer. Statethe type of ink that is being used and the order that the tanks areinstalled in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the test results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Remember: Good things happen to those who Rate.
Mike
Aug 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
My printer won't print because there is more than one inktank of the same colour
There are 2 types of black cartridge, CLI-8Bk Black Ink Tank & PGI-5 Pigment Black Ink Tank. These must be installed in the correct order as below. Have you replaced a black cartridge & perhaps used a different type? Here is a link you can get more info from: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11994
Aug 05, 2007 | Canon PIXMA iP5200R InkJet Photo Printer
Canon i80 InkJet Printer Logo
171 people viewed this question
old marine
old marine
