HOW TO SE nMAXTOR SERIES 3,5 hdd TO Master
HOW TO SET MAXTOR SERIES 3,5 hdd TO "MASTER" I wish to use it as an external HDD
  • 129 Answers
Please find the link to set your Hard Disk to master mode
http://www.tacktech.com/display.cfm?ttid=379
Posted on Feb 08, 2010
Can't read HD-- I/O error
"Joecolvette" has probably got it right, I've seen this before. The HDD enclosure circuit board has a fault. Can be resolved by replacing the enclosure. Plenty on ebay, just ensure you buy one with the correct HDD interface (Sata or IDE).
Alternatively, if you have a tower with a spare port, you could take the HDD out of the caddy, install it in the tower as a "Slave" (check jumper settings) ensuring the system drive is set to "Master". Then you can check whether the HDD itself is at fault.
Apr 28, 2012 | Maxtor Computers & Internet
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
Aug 04, 2010 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
Maxtor 90845D5 EIDE HDD jumper settings
Connected the 2 pins furthest away from the power connector.
Pin 1
J1 IDE Connector | J2 Power
| .................... || @ * * * || X X X X |
| .......... ......... || @ * * * * || X X X X |
J50 Master/Slave -----+ | | | | | | | +-+12V
J48 Cable Select -------+ | | | | | +---+12V Return
J46 4092 Cyl Limitation---+ | | | +----- +5V Return
J44 Factory Reserved -------+ | +------- +5V
J42 Factory Reserved ---------+
Hope this helps.
Andy
Jun 28, 2008 | Maxtor Hard Drive
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
