Question about Bernina Bernette Deco 600
My upper thread has stopped picking up the bobbin thread. I have a new needle in the machine, which sewed three and a half designs perfectly. The thread broke on the outline of the last design and even after re-threading upper and lower over a dozen times it still will not pick up the bobbin thread. I have taken off the plate and there is nothing jammed in the bottom of the machine, bobbin is new. Thanks!
    Problem Solver:
  • 23 Answers
Try changing the needle again. I have had some cause me trouble even if new. And make sure the bobbin is in the right way.
Posted on Feb 13, 2010
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
My Ruby Viking will not pick up bobbin thread
Install a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread.
Verify the machine is threaded correctly.
If it still will not pick up the bobbin thread, most likely it is a needle/hook timing issues. There are many web sites and videos online explaining sewing machine timing. Or take it for service.
Aug 19, 2016 | Sewing Machines
Having trouble picking up the thread from the bobbin
Try a brand new needle. Verify that the machine is threaded properly--both upper and bobbin threads.
If it is still not picking up the bobbin thread, it is likely there is a needle/hook timing issue requiring service.
May 17, 2016 | Singer 4411 Heavy Duty Sewing Machine
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
Thread jamming in bobbin mechanism, breaking upper thread and jamming bobbin.
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
May 04, 2012 | New Home Sewing Machines
My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
round needle--the groove in the needle should face away from the shaft.
Apr 26, 2012 | Juki HZL35Z Mechanical Sewing Machine
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
578 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
