Question about Thermador CJ302U Double Oven
Thermador cj302zs sn#373020081104000256
Shows f53 the door on upper is locked and makes noise like it is trying to unlock. the time clock for micro will not count down. is there away to over raide to open door . as we have food in it?
  • WESTVALLEY Feb 02, 2009
    I HAVE A THERMADOR CM302US WITH THE SAME EXACT PROBLEM.
    SOMEBODY PLEASE HELP!!!
    THE UPPER OVEN DOOR ATTEMPTS BUT FAILS TO UNLOCK AFTER CLEANING CYCLE. IT INTERMITTENTLY MAKES A BUZZING SOUND AS IF IT WAS TRYING TO OPEN BUT IT WON'T.
  • UnhappyInKY Feb 10, 2009
    I had the same problem. Thermador sent repair people repeatedly, and their determination was that the upper latch was broken. Thermador finally gave us our money back (it was a brand-new oven that had never been used by anyone) because they said that the company they contracted with to manufacture latches went out of business. To get the latch open, you just need to get some kind of thin wire (a coat hanger or something thinner, more flexible preferably) and slide the latch. I don't know if you slide left-to-right or right-to-left. The latch kept making a whirring sound when the oven door was closed and chirped an error message when the door was open, so we finally had to turn off the circuit breaker to the oven. I had this problem beginning September 2008 and finally got a check from Thermador in February 2009.
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: oven door wont open code f53 thermador how can i
Hello,.
Welcome to FixYa.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
I have double wall unit Thermador oven. After self cleaning, the door can not open. Or may be I hit the panel lock , so the door is lock. How to unlock?
Hello April,
If any OVEN FUNTION is being used...
The controls cannot be LOCKED off...
So no... REQUIRES PUSHING 2 buttons & holding
for four (4) seconds... (not likely to be accidental)
The steps to Lock & Unlock are the same...
(see reference page (click here)
Thermador SCD302 Care And Use Manual Child Lockout
Touch and hold the COOK TIME pad and
the STOP TIME pad simultaneously for 4
seconds.
Likewise SELF CLEANING is described in great detail.
(double click this URL)...
Thermador SCD302 Care And Use Manual Page 29
ELSE...
Please contact THEM if you have questions or comments.
Phone: 1-800-735-4328 or reach THEM through their
website at www.thermador.com
Hope this helps
Carnac the Magnificent
Dec 20, 2017 | Thermador Ovens
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
On self clean mode with thermador single oven showing f52
F52 means your upper oven door latch is acting up.
This means that the upper oven door is not in the correct position; check it or replace the upper oven door latch assembly for fixed.
I hope helps.
Jun 23, 2011 | Thermador Ovens
Self clean wont turn on!
Hi, If the self-cleaning operation on your double oven will not work, make sure the oven clock on the upper oven shows the correct time of day. In addition, Make sure the Lock Lever is in the cleaning position, pushed all the way to the right on the top oven. If a delayed start time has been programmed, that may be the cause of the cleaning cycle not beginning right away.
Thanks for using fixya....
Oct 28, 2010 | Thermador SC302T Electric Double Oven
Oven door wont open code f53 thermador how can i get it open food is in it
Hello,.
Welcome to FixYa.
Regards,
Macmarkus :)
Sep 29, 2010 | Thermador C302U Electric Double Oven
LED says "Locked" can't turn on stove. How do you unlock it?
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 16, 2009 | GE Profile JTP18 Electric Single Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Door is locked- F53 Error
OK...you need to replace the lock, but first you need to get the darn think open. I looked at it, couldn't figure out how, and left it. My 14 yr old starting looking at it (after the kids had their TV, Ipod, etc taken away from him for the weekend.....) and he took a coat hanger from the side to pull the latch open.
The rest is straightforward sheet metal disassembly except for the front panel...label the connectors with a piece of tape before you pull the cables connecting the front panel (unless you are able to read a schematic). You can buy the part from AppliancePartsPros.com
AP2836100 (486324) Latch, door (microwave)
for about $100....next day delivery, and your ready to cook your Christmas goose!
Aug 22, 2007 | Thermador C302U Electric Double Oven
Thermador CJ302U Double Oven Logo
198 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
