Question about Refrigerators
Both refridgerator & freezer not cooling
Had repairman in last week when unit stopped working.He replaced the defroster switch & it worked fine. But now neither the fridge or freezer are cooling properly.
  • Refrigerators Master
  • 8,220 Answers
Get him back out there
Posted on Feb 08, 2010
Frigidaire Refridgerator not cooling. Worked for about 2 weeks after replacing defroster
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute
Jun 01, 2012 | Frigidaire Refrigerators
LG elecrocool refridgerator not cooling
it is mos tlikely frosting up on the evaporator, this shows up as frost on the back wall of the freezer that means its not self defrosting, check the defrost system, defrost termination therms can go bad, and need replacement, defrost elements can short out, defrost board if it has one may be bad.
Feb 21, 2012 | LG Refrigerators
I have a GE side by side refrigerator, model GSL85JFPHBS. It sstopped working altogether last month. first the refrigerator stopped working, two day later the freezer part stopped working. I had someone...
I think you meant you have a GSL25JFPHBS (not 85).
It sounds like you have a defrost problem. If your refrig. was off for some time, like a day or more, or it was manually defrosted, it would work for about 2 weeks before the problem would re-occuer. This is caused by a build up of frost on the cooling coils, preventing air flow over them. Un-load the freezer and remove shelves and the back wall inside the freezer. Melt the frost with a hair blower, and replace the defrost heater (part # WR51X10055) and for good measure, replace the defrost thermistor (part # WR55X10025) located at the top of the cooling coils.
Mar 21, 2011 | GE Refrigerators
My refrigerator is cool but cool enough and so is my freezer cool, but not cold enough to freeze anything. It seems that the motor is running.
Your refrigerator's defrost heater is not working. The frig's cooling coils are frozen up because the defrost switching unit needs replacing. It is a cheep fix. Call a refrigerator repairman and have it replaced. Max cost is around $ 100.00 mike micmor68@gmail.com
to prove this turn off refrigerator a couple of hours with the doors open and you will notice water appear on your floor as unit defrosts and it is more water than your defrost pan can hold. As it overfills it will spill over onto your floor. If you turn it back on it will work properly for about two weeks and it will start the problem again. mike micmor68@gmail.com
Oct 31, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Freezer stopped working
ok,is the freezer fan working?is there frost buildup in the freezer?it sound like you have a defrost problem whick means your defrost timer,defrost heater or defrost sensor has failed,you need to check all the defrost parts to pin point the problem,let me know what you find-mike
May 22, 2008 | Traulsen Reach in Freezer - G12010
LG bottom freezer refridgerator ER FF
I see this problem daily in the UK, turn off, defrost overnight,replace defrost sensor in freezer, all will work ok within 24hrs. Regards Advisor
Aug 18, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
Refridgerator not cool enough.
sounds like the probable cause is defrost heater. get someone to test the element.
May 27, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
