Question about Toshiba Satellite Pro A210-EZ2202X Notebook
My toshiba A210 laptop will not power up all neons lighting wont power up with or without battery
  • 2,229 Answers
It looks like you are saying that you can't power up the computer at all.
First, check the power adapter to see if it is putting out the voltage it is supposed to--about 18 volts.
If it is putting out the voltage and you hook it to the computer, your battery should charge and the computer should start. If it does not, then you have a bigger problem. It could indicate bad memory (but probably not, as there should be some flashing of the lights on startup) or a motherboard problem.
Posted on Feb 08, 2010
I have a toshiba A210-1AO with AMD Turion64. I turned it off normally and next day it wont start. The power led is on, it does the dvd startup check noise and then nothing. Blank screen. I tried the...
Age and dust accumulation. try blowing the case out or get a vacuum cleaner and clean out all the ports. If this doesn't work, you may have to take it to a computer repair shop to get it cleaned and serviced properly. The heat paste on the processor may have dried out and be causing an overheat.
Apr 12, 2013 | Toshiba Satellite Pro A210-EZ2202X...
After formating WINDOWS 7 I need to download camera software for A210 laptop,where find this online,thanks
You will find all the drivers for the Toshiba A210 laptop at the link below, if there is no driver listed on the website for your operating system (Windows 7), then it is likely that the camera is not compatible with the new OS.
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
Aug 09, 2011 | Toshiba Satellite Pro A210-EZ2203X...
Toshiba satellite a210 was on and working yesterday left it came back to it later it was off no power to it no battery no lights no nothing completely dead , power lead works but will not do a thing.
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
Visually inspect the power jack to make sure it is not broken or damaged.
Test voltage on the power jack to make sure it is not damaged.
Sep 26, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba laptop a210-15k wont turn on .power lights and battery lights on .when i pres the button of power it begins to stars and I hear the noise of the fan moving for 10 sek and then the fan slows down...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 10, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba Satellite A210-11p.Screen is blank.Does
Take a flashlight and shine it into the screen once PC is powered up. If you can faintly see your computer booting up in the background you probably have a bad LCD inverter card. They go for under 10$ on E-bay. Cheap and easy fix if that is the problem. Good luck, Todd
Dec 22, 2009 | Toshiba Computers & Internet
My Laptop Won't Turn On Even When I Push The Start Button
try pulling the battery out then with the power supply connected see if it starts, if it does then your battery is bad and is bringing down the power from the power supply.
Jun 02, 2009 | Toshiba Computers & Internet
Toshiba Satellite Pro A210-EZ2202X Notebook Logo
565 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
