Question about Frigidaire GLTF2940ES Front Load Washer
No final spin- washer tub rocks back and forth and times out
Washer times out and shuts off at 6 minutes remaining in final spin cycle.
Any function- heavy, normal, permanant press etc. Door lock working OK Error code E47
Can't clear code even by un-plugging electrical cord.
  • 0623 Mar 21, 2008
    Want spin
  • Anonymous Mar 22, 2014
    Our Washer won't do a proper final spin. It washes fine and rinses fine, but when it comes time to drain water it does an initial spin and then the drum rocks back and forth. We want to check if something is stuck in trap and hoses but cant figure out how
    President:
  • Frigidaire Master
  • 2,651 Answers
E47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Posted on Feb 23, 2008
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Spin cycle
moduel or triack motor controler
Aug 12, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
The digital timer on the machine will say 1 minute to go, but the machine will run on the spin cycle for 6 to 8 minutes before it finishes. Is there a part I can replace to correct this problem?
Your washer displays an estimate of time remaining in the current wash cycle. That estimate is based on the load finishing without any delays. Prior to going into a high speed spin, your washer "tests" the load balance by either rocking or slowing rotating.
If it senses and off balance condition, it will attempt to "rebalance" the load by itself and then retest, rebalance, etc. until it is satisfied that the load is as balanced as possible. Then it begins to spin. When your washer takes longer than is predicted in the display, it is because of this.
Happy washing...
Jan 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tub not spinning with load
I would suspect a faulty motor control board. not much you can do to test it unfortunately, aside to replacing it and see if that fixes the problem, but definitely the best guess. Also known as a speed board.
Apr 07, 2010 | Frigidaire GLTF1240A Front Load Washer
Kenmore Elite HE3 Washer 2 Hour 'Normal" wash cycle
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Kenmore front loader washer. During the last load it started making a loud sound while in the final spin and then would only spin really slowly about 1/4 of the way back and forth. Then it would...
sThere is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 19, 2009 | Kenmore 43142 Front Load Washer
Will not fully spin on spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 18, 2009 | Kenmore Washing Machines
The tub never starts to spin when it hits spin cycle.
If your washer functions when the door is shut it cannot be a door problem. The likely thing here is you may have a drain problem....your drain oulet filter (or out pump) could be blocked. This requires cleaning; when the washer goes thru all the functions except spin it is most likely your drain is clogged. Aft u have cleaned the filter & pump check by a small spin. Before you attempt, wall socket off & keep bucket handy to collect water.
Apr 29, 2007 | Crosley CW6000 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
767 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
