Question about Sony RDR-GX7 DVD Recorder
MY recorder is long longer recognizing DVD's when I insert it into the recorder. I have tried retail purchased DVD's (movies) DVD's that I had recorded on this same recorder and previously viewed on the recorder Blank DVD's dvd-r's DVD's recorded on another recorder. I inserted a few that it properly loaded and when I reinserted it later, message said "can not play this dvd".
  • smsneado Feb 08, 2010
    I am going to try your suggestion as it has never been cleaned and everything else appears to be working properly. I will get back with you on my results. thanks
  • smsneado Feb 09, 2010
    I am attempting to try your solution with my problem. I began to remove the cover and am trying to expose the lazer lense. I can't seem to get to it. I am not sure of the exact location. Is it located inside the enclosure that holds the dvd? If so, how do I remove the board resting above it. there are wires connected that i can't seem to remove. am i going to have to go to a repair place. so far i have removed the top cover, the screws holding the motherboard looking thing, the screws holding the metal platform below it and the screws holding the front of the recorder. HELP.
  • 1,476 Answers
Sounds like your unit has a dirty laser lense. Not too difficult to fix. If you are not sure or familiar with this procedure do not attempt it. Unplug unit, Remove all covers to expose the lazer lense (looks like a fisheye facing straight up. Using 200 proof alcohol and commercial grade, lint free swabs wet the swabs with alcohol and gently clean the lense with as little pressure as possible. Blow any dirt, and dry the lense with canned air. Reassemble everything and you should be good to go. If your unit still will not recognize discs you probably have a problem with the lazer losing power or it is dead. Either way you would need a professional tech to repair it. Let me know how you make out.
hardrocko
Posted on Feb 08, 2010
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
Will not recognize disk inserted
Try changing your DVD regional locale. Some dvd/roms will restrict certain media if the locale is set to some other region than your own. The other thing you can do is update the drivers - - this seems arbitrary and you probably hear that often when asking a techie guru... But it is well justified. Also try different brands of dvdrws. Some dvd roms will restrict +rw - rw. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/nicole_525c14680d45ee5d
Feb 15, 2014 | Funai ZV427FX4 DVD Recorder/VCR Combo
How to watch movie here??
Perform an observation of the computer devices disk location compartments. For example, computers would provide logo indication of what media disk is displayed on the location drive. In situation that the computer disk area has CD rom, DVD rom, or CDRW or DVDRW is indication that movie disks with mentioned logos is displayable at insertion. Second, observe that the computers disk logos made specific demarcations least an alternate disk would least produce impressive expectations. Acquire a disk media at retails with movie material. Once inserted in computer disk compartment should take effects discussable. For example, the computer is prior designed to auto detect media material at insertion in components. Computer program also known as multimedia player displays momentarily after disk has been detected on computer. Compatible disks would display the media expectation either as audio CD or DVD movie. Alternately, in situation that the computer least displays recognizing media disk is indication that each entities has malfunctions. First disk media that least has movies or encountered malfunction is least recognized at insertion in computer compartment. Second, computers that least has the innovativeness of the disk media least recognize an impression. Alternately, computers that an internet connection would recommend a means to restoring malfunction that is encounter at inserting media in compartments. An expectation is to perform update to capture displays to outdated disks. Alternately, modern disks are recognized on computers that have network connections as least having the programs to capture an impression.
Feb 27, 2011 | Computers & Internet
Does not recognize the DVD and won't let me record or DUB.
Try a lens cleaner for the DVD player. If this doesn't resolve the problem, your player may need repairs. Service can be obtained by returning to the retailer of purchase.
Nov 19, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Can anybody help me, I purchased a Samsung dvd recorder model dvdvr350m, since purchasing the unit it will not recognize that it has recordable dvd's in it (dvd-rw),it tells me no disc inserted please...
Did the sales guy use the same DVD-RW that you did? Maybe the brand you are using is not of good quality and can not be recognized by the recorder. If he did not use the same disc did you notice if he used DVD-RW or DVD+RW? Some DVD-Recorders only recognize one or the other but this is kind of rare these days. I recommend verbatim brand discs. They should be available for sale at any shop. If you want the ultimate in quality DVDs then go with Taiyo Yuden. This Japanese brand invented recordable media and in addition to that they are obsessed with quality. www.supermediastore.com is always where I get my discs.
Thanks for reading!
Hope this was helpful
Apr 30, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Titles
you need software such as this
then you can do much more than titles to your DVD movies
if you are talking about retail movies you've purchased and not home movies, you have to rip them to your hard drive then use something like the above software
thanks for rating
Jan 10, 2008 | Philips DVDR3505/37 DVD Recorder
Sony DW-Q30A Problem
the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
May 30, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
NONFINALIZED DVD'S THAT ONCE PLAYED WILL NO LONGER PLAY
This seems to happen with alot of dvd recorders especially if discs left unfinalised for long periods of time.This happens on all makes of recorders not just your model.Also the quality of the dvds being used can be the problem.How old is your recorder as the only other problem which could cause this is the laser losing power
May 09, 2007 | iLO DVDRH04 DVD Recorder
Sony RDR-GX7 DVD Recorder Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
