After adding a network printer which is on a Windows 7 computer - on a XP computer it is possible to open the printer but printing test page crashes windows explorer
  • cbf4 Feb 08, 2010
    I have connected the printer directly to the XP computer and it works fine.
    The printer works fine connected directly to the Windows 7 computer.
    The XP computer is able to view the W7 computer and able to add the printer that is connected to the W7 computer and even
    open it to view the queue & proporties. It is when viewing printer properties on the XP
    computer and then selecting print test page that the error msg comes up - explorer has
    crashed, send crash report etc..... nothing obvious in the various logs.....
    same problem and symptoms on a 2nd XP laptop -
    I have disconnected, deleted printer and reinstalled printer on W7 computer
    Both computes are on a local network - connected to a wireless router/hub.
    File sharing -XP can read/write file system on W7 - is fine
  • cbf4 Feb 09, 2010
    How do I check that 32-drivers are installed?
    I try to install them with a Samsung executable but it aborted installation because
    of running on a 64 machine - so if they are missing how do I get 32 driver installed
    on a 64 machine?
    thanks
  • Office Equip... Master
  • 5,379 Answers
Check your installed print server software for 32-bit and 64-bit versions. Both versions need to be on the machine that is directly connected to the printer, if you have a mix of the two types of Operating systems. 32-bit XP is very common and Win7 64-bit is becoming widespread.
(For HP printers using the manufacturer's UDP software, I found that if the printer was installed directly on a 64-bit Win7 machine, it failed. After installing the 32-bit software version in addition to the 64-bit, all the problems went away.) At least with the HP software, we did have a few minutes of confusion trying to find where the driver actually ended up. Double-clicking the downloaded file unpacked the drivers but didn't install them at the same time.
I hope this helps.
(obviously there are no firewall problems. I'll also assume the printer drivers were loaded without a problem on the two individual machines. This may have meant connecting it to the XP computer for a few minutes via the USB cable with some printers; consult your manual or the online support for the model.)
Posted on Feb 08, 2010
  • 1 more comment
  • Cindy Wells Feb 08, 2010
    The crash makes me think that it is a communication error of the type I described. With certain HP printers, I needed to install their Universal Print Driver for PCL5 for both 32-bit and 64-bit Operating systems on the machine physically connected to the printer. Otherwise I saw the printer on the network but couldn't get any document to go through. The UPD acts as a print server and interprets the data as it comes over the network into a printer-ready format.
    In between my tests, I had to force the queue on my XP machine to empty with Start Run "Net Stop Spooler" and "Net Start Spooler" (omit the quotes). Otherwise the first test page stayed in the queue through reboots.
    (At first glance, just having the local drivers and the 64-bit UPD driver seemed like it should have covered the 32-bit option. However, 3 hours of fussing proved the need for the 32-bit version. It's certainly worth you checking your printer's documentation and drivers.)
  • Cindy Wells Feb 09, 2010
    Since you mention Samsung, then it's not one of the printers I've set up on network servers in the past (HP, Epson and Oki). Most of the Samsung printers I've read the manual for had an ethernet port and got set up by connecting them to the router or switch. You need to look up creating a print server for your printer. HP makes it simple.
    I wish I could be of more help.
  • Cindy Wells Feb 10, 2010
    I finally found the Win7 related help page that I'd forgotten:http://technet.microsoft.com/en-us/libra... . This is how to add drivers once you have the print server installed (like the Universal Print Driver I've mentioned before). Perhaps with additional information on your printer, I could find the appropriate driver for your model. (We've only done HP printers with Win7.)
How do you connect a Toshiba estudio 202L to a windows XP professional version 2002 service pack 3?
Any device that is not made to work on windows 7-10 and higher (like any XP device) will not work.
Jul 28, 2017 | Toshiba e-Studio 202L Copier
Networking issues
Sounds like your printer isn't configured for "sharing." Go to Control panel > Network and Sharing Center > Choose homegroup and sharing options. Make sure Printer has a check mark.
If you have any other computers, check them to see if you can print from them.
Jan 14, 2012 | HP Photosmart C4180 All-In-One InkJet...
My x3430 is not printing can u help
Please follow your user manual and do a factory reset. Then try printing again. It will print for sure.
Also check the cartridge. Send more details so that we can help you better.
Mar 22, 2011 | Office Equipment & Supplies
My Hp Photosmart C5820 all in one printer is connected to my HP Pavilion dv6000 laptop (Windows XP). How do I share this printer wirelessly with my new Dell laptop (Windows 7)?
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer. You need to install theprinter driver on the computer and configure it as a Shared printer. The other computers on thenetwork need to add this printer to their computer. Follow these steps toset-up a shared network printer :- 1. Connect the printer tothe computer and install the printer driver. 2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK 3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.
Follow these steps toconfigure the computers on your network :- 1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for aprinter - Next 3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Usethis printer as the default printer - Next - Finish 5. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation. b>
Mar 04, 2011 | HP Computers & Internet
I'm having issues getting the lexmark z25 drivers for windows 7
There is no driver for windows 7, in fact, they don't even have a vista driver for this printer.
If you absolutely must use this printer under windows 7, you could use VirtualBox (virtualbox.org), to create a virtual computer, install XP in the virtual computer, then redirect the usb or lpt port to the virtual computer. Then you'd have to save the document to a shared folder, open the document in the virtual XP, and print. Even sharing the printer over the virtual network (or off a real xp machine and real network) won't work, since win7 doesn't know how to 'speak' Z25 'language'.
Frankly, it's a LOT easier, and really, when you consider your time, cheaper to buy a new printer that has a windows 7 driver.
Sep 08, 2010 | Lexmark JetPrinter Z25 InkJet Color...
Using windows 7. Have a Zebra LP2844 printer connected to another windows XP computer. Unable to print to it across network. Zebra prints fine from all other computers on network.
I dont think this model has a Windows 7 driver. You can check the Microsoft hardware compatability list to see if your printer is listed.
Apr 23, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\192.168.0.50printer shared name where 192.168.0.50 is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
Can't print from my mac to my canon mp980 wireless printer
Sounds like when you added xp you inadvertently installed new print driver on server.
Try rolling back driver. But may drop xp from printing.
Best solution network printer to router bypass server. Will require hard wire from printer to router. disconnect from server may need network card for printer.
Mar 08, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
168 people viewed this question
k24674
jasbo
jasbo
