Question about Acer Aspire 3624WXCi Notebook
The power of the adapter shut down when it plug to my laptop
  • 35 Answers
The problem there is your dc jacks which may not be grounded. You may have to repair your jack. I do suggest if you can get your hands on another charger, try that first.
Posted on Feb 08, 2010
I have a dell inspiron 570 when I turn on the dell it starts to power up then shuts down with in 3 to 5 sec , but when I wiggle the power supply plug to the mother board it trys to power up again only to...
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 28, 2013 | Computers & Internet
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
Sep 13, 2011 | Toshiba Satellite M205-S4806 Notebook
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Toshiba Satellite A305 AC Adapter
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
I heard a "snap" noise and my laptop shut down
Most of the time when you hear that kind of noise and it was plugged into the AC adapter, a power surge hit your pc and it will need a new mainboard to power back on.
Sorry for the bad news.
C2Solutions
Feb 10, 2011 | Toshiba Computers & Internet
When I put my adapter inside for charge my laptop turns off and the light is on saying that is charging but its doing nothing pls help. Regards
Read the article below, may it will help.
Possible troubleshooting steps and repair solution:First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Jan 09, 2011 | Toshiba Tecra M5-384 Laptop AC Power...
Computer shut down
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
Jan 29, 2009 | Compaq Presario Notebook
Acer Aspire 3624WXCi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
