Question about Health & Beauty
I have a set of hanson kitchen scales and i cannot change it from fl oz to grams etc
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Posted on Mar 13, 2010
How many cups of water is 250 ml
not sure if this will help you out.
American Standard (Cups & Quarts ) American Standard (Ounces) Metric (Milliliters & Liters) 2 tbsp 1 fl. oz. 30 ml 1/4 cup 2 fl. oz. 60 ml 1/2 cup 4 fl. oz. 125 ml 1 cup 8 fl. oz. 250 ml 4 more rows
Equivalents and Measures ' Exploratorium
https://www.exploratorium.edu/cooking/convert/..
or try this link... How many cups of water is 250 ml Google Search
Oct 12, 2017 | Kitchen Appliances - Others
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
Change lb to gram
Number of grams multiplied by .0022 = lbs,
Dec 10, 2014 | Salter 2001 electronic kitchen scale
Scale stopped giving oz, grams, and kilograms.
Get back to the menu by holding 'unit' when powering up.
Set default values to below by hitting unit to increase digits, and z/t to save.
1 - 00 (press 'unit' until 00 is displayed, then press z/t)
2 - 15 (press 'unit' until 15 is displayed, then press z/t)
3 - 00 (press 'unit' until 00 is displayed, then press z/t)
4 - 05 (press 'unit' until 05 is displayed, then press z/t)
It will only save if you see an 'f' display before turning off.
There is a limit to the amount of times the unit can 'flash' to the memory. If you cannot see the 'f' display, the memory is full and you cannot change.
Hope this helps!
Mar 10, 2014 | Kitchen Appliances - Others
I have the Salter Scales model 2040, it is currently sent to oz, do you know how to change to grams as there is only 1 button. thanks
I just had a play with mine as I wanted to change the weight mode too.
The solution is this:
While the machine is OFF, press and hold the button for about 5-10 seconds.
The display will go from 8888 to show the weight measurement (lb oz) at the top of the display.
Press the button to select the weight you want.
You should be able to continue with your baking :o)
Hope this helps
Oct 09, 2010 | Salter 2001 electronic kitchen scale
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
Setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
Health & Beauty Logo
2,197 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
