Question about Whirlpool Refrigerators
I have a refrigerator model ed2fhexns01. How do i replace the water filter? I have the filter . I know it goes behind the grate butm I can't get the grate off.
    Problem Solver:
  • 11 Answers
Its hard to remove, but you gotta pull from each side really hard. Once you get it off turn the cover on the filter counterclock wise until it comes out. If you can't remove it get someone who is stronger. This should work, do em all the time.
Posted on Feb 09, 2010
Just purchased a RS53K refrigerator and dont know where to install the water filter
Check at the bottom of the fridge where you should find a cover. Sometimes solid or looks like the floor grate. Pull it forward and you should find another cover to get to the filter. Be sure to shut off the water before removing the filter.
Jul 02, 2017 | Refrigerators
I cant find the filter on my hotpoint no frost refridg.number csx22gr where is it.
your model number doesn't come up.if it's an older machine some didn't come with water filters,you had to add an inline filter on the copper water line,you would run your copper,go down the cellar or behind the machine,cut the copper and the filter connects in between the copper where you cut the line.if you do have a filter it could be in the fridge section top right side or down in the bottom kickplate.i found your model the a was missing after the b baww.it doesn't show a filter,this is an older unit,check behind or in basement,wherever the water line goes and see if there's a filter added into it,if not you can cut the copper and add a filter yourself.home depot sells them
http://www.homedepot.com/p/Whirlpool-In-Line-Refrigerator-Water-Filter-4378411RB/202204720#.Ug7jNxXD_X4
Aug 16, 2013 | Hotpoint 21.7 cu. ft. Side-by-Side...
Where is the water filter on Whirlpool Model SB540W Refrigerator
The filter is more than likely located at the bottom of the machine where the grill is. You'll see an area that is circular with a handle that sits flush with the grate itself
Jun 05, 2012 | Whirlpool Refrigerators
There is hardly any water flow from the faucet in the refrigerator door. A re light at the top of the refrigerator side sys the water filter is plugged. Where is the filter and how do I clean it? ...
Without knowing the manufacturer and model of your fridge, it will be impossible to tell you exactly.
Some manufacturers have the filter installed on the back side of the fridge, some will have it behind an access panel. Others will have the filter located at the bottom kick panel on the front of the fridge. Others will have it located in the refrigerator compartment, behind an access panel.
If you post the make and model, perhaps I can find the user manual for you, maybe a source for filters as well. Filters are typically replaced, and not cleaned.
Sep 11, 2010 | Kitchen Ranges
I have a friend with a Whirlpool ED5PHAXMB00. It's producing ice, and dispensing ice, but no water will dispense. She changes the filter evey time the light comes on, so am thinking it's not that. Have...
Some refrig's , water goes to filter first , some thru water valve first and then the filter . On this model , it goes to the water valve first , then the filter .
1) never change the filter just because the light says to . Only replace when icecubes get small or when water flow from dispensor slows . A filter can last 6 mths- 1yr. and sometimes longer .
2) the resevoir is in the refrig section , behind the lower crispers
3) the water valve is probably the problem
pt# 4389177
Sep 09, 2009 | Refrigerators
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
The water dispensor is dripping water, what do I need to do to fix this thanks
On back of refrigerator there is a water control valve. One goes to ice maker and the other goes to the water dispenser. Unplug the one that goes to the dispenser and if the water continues to flow then you will need to replace the control valve. If you could find the model number near floor and behind the fresh food section door, I could tell you which part number you need, Let me know what you find, Thanks, Sea Breeze
Jul 18, 2009 | Kenmore Refrigerators
Mold in water dispenser tube
Your refrigerator has a filter system below the bottom and behind the kick plate. Two or three times you need to turn the water supply off to refrigerator and fill the old filter with clorox to kill the algae growing in the storage tank and after you finally get this out and purge the chlorine from system will you be able to use the ice or water to consume. I know this seams harsh but really there is very little else that can remove this without changing the whole water system. Once this is done change the filter regularly and this will help, click on link below and place your model number into the model search feature. This will give you pictures of the parts and there location. Let me know how this goes, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 23, 2009 | Whirlpool ED5FTGX Side by Side...
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
48 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
