Question about Pioneer Elite PRO-1140HD 50 in. Plasma HDTV
My HDMI Terminals for Pro-Ro6u Media Receiver is not working. Do you think it is the terminal or the HDMI Cable.
    Scholar:
  • 50 Answers
This could be an HDCP "hand shake" problem. Try turning both the TV and the connecting device off, connect the two using HDMI, turn both of them back on, select the proper input and see if you get a picture. If nothing happens try the other HDMI inputs by following the steps listed above. I hope this helps.
See the following Thread for more information about problems with the Pro-Ro6u.
http://www.tv-forums.com/forum/TV_Equipment_C4/TV_Repair_Forum_F3/Pioneer_Pro_RO6U_Media_Receiver_P46635/
Posted on Feb 08, 2010
  • Fix me too Nov 03, 2010
    I had the same problem with non-functional HDMI inputs with this Pioneer Elite Pro RO6U and found the solution. Using the remote control, first select the input you intend to use (HDMI inputs are either 1 or 3). First verify the screen displays either input 1 or 3 , then press the Home Menu button at mid height right side on the remote control. In the Home Menu, click down to the Option menu and press Enter on the remote. In the Option menu, click down to the HDMI Input and press Enter on the remote. Highlight the the Setting tab and press Enter. Highlight Enable and press Enter. Use the Return button on the remote control to back out of all these menus.
  • Winson Hsieh
    Winson Hsieh Dec 09, 2013
    This was the fixed. Thanks for posting this solution.
My receiver PRO-R06U broke. I need a new one. The main board broke. Please let me know if there is a place in Chicago where I can get it or mayby a replacement for this receiver. Thank you.
Posted on Oct 20, 2010
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha reciever doesnt recognise hdmi from Mac laptop
Max does recognize receiver over HDMI-CEC.
The problem is that DVI output is for video only. Macbook won't (and can't) output audio via DVI. So yamaha receives only video signal via the HDMI connector. You can check that by pressing Option button on yamaha remote and choosing Signal Info - you will see info about video, but no audio signal present.
May 22, 2009 | Yamaha RX-V563 Receiver
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Video Inputs for Denon AVR 589
manual is here: http://www.usa.denon.com/AVR-589-OM-E_006.pdf
Note on page 11 says "because video signals are out put from the AVR-589's monitor output terminal IN THE SAME FORMAT AS THE VIDEO SIGNALS, THE MONITOR OUTPUT TERMINAL SHOULD BE THE SAME TYPE AS THE TERMINAL USED FOR INPUT."
You cannot mix the HDMI with the others. You must therefore use the same on DVD and Cable box.
Best Regards and happy new year!
Charles
Jan 05, 2009 | Audio Players & Recorders
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
**L@@K** How To Connect Laptop To Projector To Receiver!! HELP!!!
"the PT-AE900U supports a full range of input sources, including DVD and video players, PCs and game machines. An HDMI input provides compatibility with HD digital sources, while component video input terminals deliver full-quality, detailed images from high-end, progressive-scan DVD players. The PC IN terminal can be connected to a game machine or PC. Other terminals include composite and S-video, as well as a serial terminal for connecting a touch panel controller or similar device." You can go to Dell support to either read your manual, but your laptop model's manual is there for the reading. It lists all the outputs. if you have a problem figuring which to use, they will tell you. your manual can be found at http://support.dell.com/support/dsn/dsnsearchresult.aspx?c=us&cs=19&l=en&s=dhs&Query=bWFudWFs&SystemID=INS_PNT_P4_9400&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1
You may either have to connect the laptop directly to the Panasonic, or you may be able to connect it through the Harmon Kardon, but I doubt if there will be any advantage to doing that.
Mar 14, 2008 | Dell Inspiron E1705 Notebook
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
3,061 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
