Question about Riso RZ390 Duplicator
I have a riso duplicator RZ390, THE PROBLEM IS THE MACHINE ASK ME TO REPLACE THE INK WHEN THE TUBE STILL FULL OR HALF OF INK,I HAVE TO PUSH THE CYLINDER MANUALLY; I USE A COMPATIBLE INK, AND I CHANGE TO ANOTHER KIND OF INK BUT STILL COMPATIBLE AND I STILL HAVE THE SAME PROBLEM; I USE COMPATIBLE INK FOR THE LAST 3 YEARS AND NEVER HAVE A PROBLEM; DO YOU THINK CAN BE THE INK PUMP?
  • LUIS GRANADOS Feb 08, 2010
    Problem Solver:
  • 5 Answers
There's no problem in machines, the problem is the RF tag on the tube of the ink. The rf tag prints only 20- 25 thousand pass, possible cause of ur half ink bottle is on the rf tag. maybe you reached the maximum number prints on that tube.
Posted on Jul 27, 2010
  • musthafa
    musthafa May 15, 2014
    is there any way that i can deceive this RF tag? use the ink until its over?
  • 3,741 Answers
in many units the problem occurs due to using compatible cartridges.but as you mentioned that you have been using this compatible inks for last 3 years.so its quite clear that the problem is the ink pump.its actually not releasing the ink for printing and so its showing the message to replace ink. ----- but yes there is a problem with compatible cartridges.in original and in compatible there is a bit difference in the quality of ink.in original the ink is very thin and diluted and very much refined ink.but in compatible the ink is 50 % more thicker then the original.so due to this thick ink this ink gets jammed and dried up in the ink pump so this makes the pump bit clogged and very much dried/worn out type. ----- First try cleaning the pump with clean water by removing it from the unit.but if cleaning does not helps then the other option is to get the new pump from local printer/copier repair center. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 08, 2010
  • 17,970 Answers
Its possible that the ink drum has not correctly installed. Check your RZ390 Owners Manual for this subject and the troubleshooting and error codes for solve.
Sometimes, the label on the ink cartridge oulet surface has come off or surface is with dirt, this problem appear.
Hope help with this.
CODE E4 RISO KS800
ink overflow --inside the printing drum there's a small circuit with two pin ( like needles)....there is one shorter than the other, they are very thin... you have to clean them with a small swab and alcohol, be very carefull, don't bend them....hope this be usefull to you :)
Dec 22, 2013 | Riso RZ390 Duplicator
Change ink color
first you have to drain the ink... to do this after making a master with a heavy image on it.
1. turn off the machine and start it up while holding left and right print position buttons. when machine starts up you will see a number ... press the c or stop or yellow clear to reset that to 0000.
2. place paper in the paper tray and enter 888 and press start.
3. the machine will start printing .. let it print jntil the image is very light and press stop.
4. press the c clear or stop button to reset display to 0000
5.place the new color you want into the drum and enter code 890 and perss start.
6. hold down the yellow reset button u til the machine restarts.
7. all done! but please note you will have color mixing and banding for a few thousnad copies until the old color gets purged, there is no way around this.
Jun 14, 2013 | Riso RZ390 Duplicator
I have a Risograph RZ390ui. About a week ago, with my green drum installed, it began telling me to replace the ink cartridge, even though it wasnt empty. Now I cannot get that drum to work. Now, the same...
It is possible the ink with in the tube has become unprimed, example not push up to the exit point so its drawing air and never gets caught up before the error occurs. Be careful by pushing plunger inside tube due to the ink becoming "separated" from the oil and be to "liquid" for the ink pump to do its job..If it pours out like wine its to old sry.Should be as thick as toothpaste.
Sep 14, 2011 | Riso RZ390 Duplicator
Ks 800 Riso Digital duplicator Machine my Machine problem is E 3 code (sir plz Answar )
que significa el codigo de error e13 el riso ks 800 y que devo hacer para slolucionar el problema
Feb 04, 2011 | Riso RZ390 Duplicator
Hi is it? the ink for gestetner Duplicator to be able riso Duplicator. Is the material same materials? thanks yoel
Be aware that not all people would agree with my explanations ...
All inks for duplicators are nearly the same and therefore they are mostly interchangeable. Have a look at the DPI the ink is made for. Lower resolution ink may have bigger pigments and these may become stuck in the mesh of drum or the master. At least you have to fill the ink in an original bottle to use it. Avoid air bubbles!
Please weigh the risks before you continue. Techical difficulties may apply. So only courageous people should use foreign ink. - I have done often and my risographs still work very well!
Dec 30, 2010 | Riso RZ390 Duplicator
Error code A-06-403 on the Riso RZ390 - what does it mean?
A06-403 from the manual: either the upper or lower safety switch of the paper feed tray is off. Unplug/replug or replace.
Aug 26, 2010 | Riso RZ390 Duplicator
Any procedure to change drum in riso ks800
open the front casing of the machine 6 screws. then pull of the power supply, also the the main board of the machines then, at the back of the machines, open the case and pull out the harnest that attached on drum. then unscrew the ink hub,, then unscrew the drum from the chasis , dont forget the harnest of the position A, to pull out.
May 26, 2010 | Riso RZ390 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Jan 03, 2010 | Riso RZ390 Duplicator
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
249 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
