Question about Yamata FY101-1A
Brother Sewing & Embroidery SE-2700
I am having a problem with the bobbin thread wanting to show; the top that is threaded is not showing. If you could help I would be ever so grateful.
  • 1 more comment
  • jseamon Sep 22, 2008
    I have the Brother SE 2700 and am experiencing difficulties with my bobbin thread. My bobbin thread becomes a totally tangled mess and jams the machine. I have broken two needles and it is impossible to complete my project. Please help!
  • Anonymous Jan 13, 2009
    Same issue. Wrong bobbin type?
  • singin mommy Jan 19, 2009
    Bobbin thread is showing on top and embroidery pattern looks terrible. Already messed with top thread tension quite a bit, set as low as 2 didn't seem to make much difference.
I would like to know where I buy the disk for my machine at????
Posted on Aug 02, 2008
How do you retime a machine? My machine will miss stitches ot completely break the thread. The top thread misses a lot of stitches.
Posted on Mar 28, 2008
2 Suggested Answers
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother PE770 Computerized Sewing Machine
Why does the bobbin keep showing up on top of the embroidery? I have changed the bobbin, I have rethreaded the top thread, I have changed the needle, I have cleaned the bobbin area. How else can the...
Loosen the top tension a little or tighten the bobbin tension ever so slightly. If that fails you can always color the bobbin threads with a magic marker the same color as the embroidery thread. You might go to Superior Thread's web site and try some prewound bobbins. They are worth their weight in gold. Dr. Bob knows all about all kinds of thread and is very good about answering questions. I think some of his Thread University videos are available too.
Jul 15, 2014 | Brother PE-770 Embroidery Machine
Brother se 2700 will not sew on knit fabric
Check that you are using a ballpoint needle, designed for knits. Also, be sure that the thread is not 100% cotton thread.
Jul 15, 2014 | Brother SE-270D Computerized Sewing...
Stitching trouble
Here is a trouble shooting chart - http://www.emblibrary.com/EL/elprojects/SimpleProduct_ELP.aspx?CS_ProductID=PR1238&CS_Catalog=Elprojects
I would start with cleaning (see maintenance section of the user's manual).
This has to be done more often with sewing/embroidery machines that have a drop-in bobbin.
Be sure to use bobbin thread for machine embroidery.
Always thread the machine with the presser foot up. This will insure the thread is seating into the tension control.
Apr 30, 2010 | Brother Disney PE-180D Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
I have a brother SE 270-d. my only problem is that while embroidering, the bobbin thread is showing through the design on the top. I have tried adjusting the top thread tension but no matter how I adjust...
Try making the material tighter in the hoop and check your bobbin to be sure it's a L (look at your instruction manual...it will show you which bobbin works and which does not. I say this because you have a tension problem...dont we all, Ha Ha!
Jun 22, 2009 | Brother SE-270D Computerized Sewing...
Bobbin thread comes out on top
You need to read the section of your manual that talks about thread tension. That occurs when your thread tension is off.
Dec 12, 2008 | Brother SE-270D Computerized Sewing...
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Machine embroidery
You should always use proper Bobbin Thread for embroidery - not a bobbin wound from regular dressmaking thread. You are right, the special bobbin thread is thinner so that the embroidery thread will be pulled to the underside and you get a nice shiny embroidery on top with no bobbin showing through. Wind yourself 6 or more bobbins at a time of bobbin thread to always have some on hand, or buy the pre-wound L size ones.
All embroidery machines - no matter what brand - recommend using bobbin thread for embroidery. It is readily available at all sewing stores, probably even Spotlight would carry some. If you get stuck for a supply, try overlocker thread.
Dec 04, 2007 | Husqvarna Designer I
Sewing Machines Logo
1,097 people viewed this question
Top Yamata Sewing Machines Experts
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
