Question about Gateway MT3422 RTL Notebook
Gateway MT3421 Laptop start-up Issues
The following situation has happened twice: While both plugged in and battery charged, I would try to start my computer. The lights near the touch pad would all flash signaling the start. The fan would also begin to go but the screen would remain black. After several minutes, I would try to re-start and the same thing would happen. Even though, while off, I had the Laptop plugged in and the battery at full charge, once I attempted to turn on the computer, the battery light would change from blue to red signaling the fact that it needed to charge. I've taken it to three different places with three different answers: 1) My battery is dying, 2) there are possible problems with my motherboard, 3) my computer is completely broken and I should buy a new one.
Other useful information:
The operating system is the 07 version of Windows Vista Home Premium
I bought the computer in the summer of 2007
I had to replace my hard drive in Nov 08
I have changed out the memory from 1GB to 4GB in Sept 09
Any and all help is appreciated.
Thanks!
  • 1 more comment
  • Laptop_Junki Feb 08, 2010
    Thank you for your quick response. I should add that if the battery is out, I can start the computer. It is only when I try to start the laptop with just the battery or both battery in and plugged in does the computer not start. I believe the battery is losing charge, because it is already 3 years old. However, I do not not the associated problems that come with motherboard damage. As a side note, I am currently in Germany and do not have access to another monitor or external hard drive.
  • Laptop_Junki Feb 09, 2010
    I meant to say 'do not know what sort of problems are associated with motherboard failure'. Sorry about the confusion
  • Laptop_Junki Feb 14, 2010
    Now my computer will turn on only to show the screen showing safe mode choices. This screen has squares of text missing and has a black line running diagonally through the text. I've read that this brand is known for it's motherboard issues. Is there a quick fix for this or should I just look for a new computer?
  • 164 Answers
Start by removing the battery completely, and plugging the power cord into the wall socket. If the power indicator light comes on at the converter on the cord, your power cord is fine. Then plug the power cord into the computer. If the computer starts up you know the power cord connection on the computer is not the problem. Now witrh the power cord plugged in install the battery if the needs charge light comes on you probably do need a new battery as the cells often do go dead after a period of time and wont hold a charge, this will cause the LCD screen to go black or gray, but NOT BLUE. Borrow a friends monitor and plug it into your computer as an external monitor and press the function key to toggle to external monitor. Now try to restart, if screen shows activity you can atleast check out your computer. You may want to test your connections andf then itry placing your hard drive into another similar computer and see if the same thing happens, if it does your hard drive may have a failure. You can transfer all the info from your hard drive to an external drive through a patch cable available online at circuit city for between $7-25. The two that are most useful are the CTG Laptop to IDE Hard drive adapter item C184-17705 and the Ultras USB 2.0 to IDE/SATA cable adapter item UL740112 depending on what type of hard drive connections you have. Once you transfer your information to an external you can try to restore your computer using the original system restore disk that came with the computer. Set to boot from disk and away you go... If this does not work you may have a bad hard drive or possibly the mother board. If the mother board is bad you may want to just keep the computer for spare parts as it might not be worth the cost of repairs. If it is the hard drive you can get good quality Hitachi Harddrives reasonable (for less than $90 for upto 600 GIGS on line again at circuit city without any shipping cost and will have it within a couple of days.
Hope this helps.
Posted on Feb 08, 2010
  • JM Alvis Feb 09, 2010
    I would definitely go with the battery replacement. I seriously think this will resolve your problem.
I just removed my battery on my laptop that had just been declared DOA. It started right up and now I am looking for a battery replacement. And that's a good thing. Beats the hell out of a laptop replacement. I owe you big time. How many motherboards have been replaced when all it was is a battery glitch!!! Yeah!!!
Posted on Apr 07, 2010
So the gateway laptop i have e475m it won't turn on or no lights when plugged in. The battery will charge when the laptop is plugged in.what the issue and how to fix it
Try removing power supply and main battery. Remove HDD and RAM. Plug in power supply and press ON. It should complain that there is no hardware. If it does, replace one RAM stick at a time and repeat powering up. If now OK replace the HDD. If nothing, the motherboard has issues, possibly GPU.
May 27, 2016 | Gateway Computers & Internet
Gateway laptop shuts down instantly when unplugged but fully charged.
I have come across connection issues on the battery terminals. Make sure the brass contacts are not tarnished or bent. Have you tried another battery?
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
Will not charge. Keeps saying that it does not detect a battery. Sometimes says that it is plugged in and not charging. What should I do?
If your battery has been installed for a long time [and never removed] you can get CORROSION build-up on your terminals [as with any battery]. This will quite often prevent correct charging from happening.
Try removing your battery and cleaning the metal terminals [also clean the contact points in your computer for the same reason].
High humidity work-place situations can also cause this problem.
OR your battery may be at the end of its "useful life" [around 2 years or so if constantly used without an AC power source]; so you may need to replace your battery.
Most battery suppliers can TEST your battery for you ... ok
Nov 23, 2013 | Gateway N214 Laptop
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
My laptop is a gateway Model:MC7801u. I have had it since 2008 and have had constant problems with the ACadapter and battery. It randomly decides not to charge my battery and then my battery dies and the...
Some people have successfully reset the charging system with the following procedure:
  1. Shut down the computer
  2. Close the lid
  3. Unplug the AC adapter
  4. Remove the battery
  5. Plug in the AC adapter
  6. Open the lid and turn on the computer
  7. Log in to your user account as usual
  8. Shut down the computer again, and close the lid
  9. Unplug the AC adapter
  10. Put the battery back in
  11. Plug in the AC adapter, open the computer and start up again
The battery should now charge normally. If this process needs to be repeated any time soon, the small clock and parameter backup battery inside may have gone bad. I don't know where that is in this particular model. In some designs, it's accessible from the wireless card or memory compartment; in others it's somewhere under the keyboard.
Charging failure can be the result of a broken cable in AC adapter, often caused by yanking on the cable to unplug it rather than pulling on the plug body. Sometimes the adapter jack gets worn out or the solder connection inside the laptop breaks. In these cases, usually no light comes on when you plug in the adapter or the AC power indicator light is intermittent.
Also, if you have a Sanyo battery pack there are some issues with the battery management firmware. Gateway has a BIOS update to address the problem.
Apr 15, 2011 | Gateway MC7801u Notebook
Toshiba l505 have a green light for power cord and battery but won't power up. This has happened twice. Both times it was when I was working from battery power only and the battery completely ran out. When...
Hi
have you tried to remove the battery then plug in and try to start laptop
and see if it starts up ok
then put battery back in and leave switched off but plugged into the electric to
charge up the battery for 2 or 3 hrs
then try to power up the laptop again
many thanks
Mar 11, 2011 | Toshiba Computers & Internet
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Car wont start. lights and everything comes on but no crank when I try to start car. been having to start car twice to get it to turn on. 1999 dodge intrepid
Look into the starter motor.
Car is 10 years old and starter motor problem is linked to startup issues in cars. Common issue
May 29, 2009 | 1999 Dodge Intrepid
Battery not charging
How old is the battery? If this laptop is a couple of years old, you may need a replacement, depending on how many recharge cycles have been done.
Dec 30, 2008 | Gateway MT3705 Notebook
Gateway MT3422 RTL Notebook Logo
1,302 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
