Question about Lexmark X6650 4-In-One Wireless InkJet Printer
I keep getting the 'Left Cartridge Incorrect' message despite using a genuine Lexmark 36XLA cartridge. The error started a few weeks ago so have taken the cartridge to get re-filled in case it was just out of ink (I paid extra for the XLA version as it can be re-filled supposedly). Have re-inserted the cartridge and still getting the same error - CAN ANYONE HELP AS I AM PULING MY HAIR OUT!!!
  • tricktjm66 Feb 08, 2010
    It was indeed a new, genuine factory cartridge when it was first purchased and the problem appeared before it was empty.
    I had it re-filled today to see if that cured the problem but to no avail.
    Thanks
    T
    Hi Don
    It was a new, factory genuine cartridge when I purchased it. The error started before the cartridge was empty and I decided to have it re-filled today just to see if that cured the problem but to no avail.
    Thanks
    T
    Genius:
  • 1,018 Answers
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 08, 2010
  • Don  Farrell
    Don Farrell Feb 08, 2010
    T,
    Okay, just the act of refilling the cartridge voided the warranty on that cartridge.
    May I strongly suggest that you either purchase a factory new 36 XLA cartridge from Lexmark or check in WallMart or Office Depot for a standard cartridge.
    If the new cartridge also fails, call Lexmark and exercise the the new cartridges warranty.
    Don
Why does my lexmark x5320 keep saying left cartridge is incorrect?
It is very likely the ink cartridge is defective, i would suggest you remove it an few times and then reinstall it, if the message still appears replace the cartridge.
Feb 06, 2012 | Lexmark X5470 All-In-One InkJet Printer
Error message: black cartridge unsupported
Make sure that your printer firmware is updated. Please visit the Lexmark website to download and install the Lexmark Firmware Update. Select your corresponding model to start the download.
Should the error message continue to display after successfully updating your printer, try to re-seat your black cartridge in the printer.
If that doesn't help, please contact Lexmark Technical Support Center for further assistance. Thanks.
Jan 10, 2012 | Lexmark Office Equipment & Supplies
Lexmark X4270 gives an error message...black cartridge missing. It is not missing. what is the problem
Make sure you are using genuine Lexmark black cartridge. Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try to reinsert your black cartridge and make sure it is properly seated in the cartridge carrier. If error comes back up right after placing it in the printer, then it could be a faulty cartridge. Try to replace it with a new genuine Lexmark cartridge. If you are already using a genuine Lexmark cartridge, please contact Lexmark Technical Support Center for additional assistance.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
Have a lexmark x5495 and have new cartridges. when printer is turned on, message states left cartridge incorrect.
Make sure that you are inserting genuine Lexmark cartridges and the correct versions for your model. The Lexmark X5495 takes 28/34 black or 29/35 color cartridges.
Try to re-insert your left cartridge and make sure it is properly seated in the carrier.
You can also try to reinsert your old left cartridge to determine if it's a faulty cartridge issue.
Oct 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
Left cartridge incorrect on Lexmark X4550
Both pad styles should work just the same in your printer. You need to take the cartridge back to the store and have them replace it. From time to time in the manufacturing process 1 or more contacts will mis-connect and you get the error you are talking about.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | Lexmark X4550 InkJet Printer
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Have a error message left cartridge incorrect
Hey!
Are you using Jet Tec ML32 Cartridge re-manufactured cartridges or genuine Lexmark Cartridge?
If it is the Jet Tec cartridge then it is known to be faulty - purchase a Lexmark cardridge and you should be fine.
If it is the Lexmark Cardridge then I would recommend taking all of the cartridges out, turning the printer off (from the power), turning it back on, inserting the cartridges again and checking if it works.
If none of the solutions work, then your cartridge is damaged and should be replaced.
Cheers,
Matt Newelski
Dec 08, 2008 | Lexmark X5495 Printer
I have a lexmark x4580 and was working quite happily over the last few days. i replaced its ink cartridge a week ago and just printing some documnets , it threw up an error message " rigt and left...
Clean and make sure to put it back exactly as you got it, incase you are like me sometimes, i take pictures before i remove an object, so that way i can go back and look at the picture to make sure i get it back in right
Nov 04, 2008 | Office Equipment & Supplies
"cartridge incorrect" message
Never throw out any receipts!!! A lesson my dear mum taught me a long time ago. You need to pay attention to what the printer is telling you. Incorrect cartridge error message could mean a clogged printhead, most people think they have cleaned properly but did you do it with proper cleaning solution. Was it a refilled cartridge or new one? Are you certain you did not accidentally touch the gold areas (printer points) as this can put oils and dirt or residue on the cartidge. Gently wipe both heads on cartridge very softly with a non perfumed baby wipe! Yes a baby wipe (people laugh at me until they see their printer go again!!!) Now try printing again. You can get rid of error message only when you fix the problem. If nothing helps, try uninstalling the printer and reinstalling with original operating disc. And yes, the printer cartridges can be faulty. Never dispose of your old receipts until you are virtually replacing the next cartridge. I keep all receipts for all costly items in a clear slip folder, or staple to original barcodes of box they came in. Did you try disconnecting usb cables to printer and reconnecting to reset it.
Aug 11, 2007 | Lexmark MFP-X3470 All-In-One InkJet...
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
295 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
