Question about Weber Genesis Silver C Grill
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
    Scholar:
  • 127 Answers
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Posted on Feb 12, 2010
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Our weber grill is suddenly getting too hot... even with only 1 of the 3 burners turned on it is over 400 degrees... any ideas?
Sounds like the regulator is not controlling the flow of gas. Try this. 1. Turn gas tank and burner control knobs off. 2. Turn tank valve on VERY slow. 3. Open front burner knob on and lite grill. Wait a minute and turn on addition burners, (if needed).
Apr 27, 2010 | Weber Genesis Silver A Grill
When the grill is on high heat for all 3 burners only heats up to
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Apr 05, 2010 | Weber Genesis Silver B Grill
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
Cannot get temperature over 300 degrees anymore
It was the regulator bypass.
For details see:
http://weber.com/support/faq/faq.aspx?id=1
Jul 18, 2009 | Weber Genesis Silver B Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Very low heat
the air control is at the back of the burner control.
you may have to disassemble the control panel in order to get to the air control.
may sure the air control is open all the way.
Oct 19, 2008 | Weber Genesis Silver C Grill
Weber Silver B - 3 burner BBQ
Check your instruction manual, you have probably set off the safety valve in your propane tank. It is set to trigger if there is an open connection, such as turning on the jets when the tank is turned off. You may have to re-connect the tank...careful of course, make sure it's valve is off.
Aug 21, 2008 | Weber Q Grill
Weber Genesis Silver C Grill Logo
236 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
