Question about Panasonic PT-LB60U Multimedia Projector
Panasonic projector Pt-LB60u has a greenish hue around part of the edge of the projection. What would be causing this?
  • 3 Answers
Upon the bulb life running out on pani projectors and proj. tv's the lamp set will start to produce a green hue get a new lamp bro. try this web site i highly recomend them www.electrified.com
Posted on Feb 09, 2010
I have a Panasonic PT-D5500U. We replaced the lamp, and then shortly thereafter, whenever we turn on the projector the power lamp goes from green and shuts off and blinks red three times continuously. ...
the problem is a known "bug" by the manufacture, which is due to low temperature issue that's detected by the processor of the projector. it will require a firmware upgrade. i'd recommend getting in contact w/ their tech support.
http://www.panasonic.com/business/projectors/ss_techsupport.asp
Jun 03, 2011 | Panasonic PT-D5600U DLP Projector
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
I replaced the lamp on a Panasonic PT-LC80U thinking this will solve the yellow appereance, but it did work, it seems that there are not blues in the image. What Can I Do to solve the problem?
here are some probable causes..
This appears to be an older model (over 5 years old) and LCD projectors turn yellow with age. It's just what they do
However, if you are projecting a computer signal or a component signal, a short in the blue signal of the cable can cast yellow hues over your image. The hue will cover the entire image as if you are viewing the image "through rose (or in this case, lemon) colored glasses" so to speak. That's an easy fix.
Harder fixes: the blue LCD panel is weaking and/or gone bad.
If you have a round yellowish spot in the middle of your screen, the diffuser has been overheated and is "burnt".
Apr 08, 2010 | Panasonic PT-LC80U Multimedia Projector
Front sanyo plv60ht projector has a yellow cast on the edges of objects..Its like thr lcd panel has shifted..is it expensive to fix?
The convergence are dead.This problems should cost u about $300-350 for parts and labors.Shop around some cost more or less.
Mar 30, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
Yellow/green hue on projection
the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine.
Jun 02, 2009 | Toshiba TLP T50MU Multimedia Projector
Uneven Color on JVC Projection TV
hello i have a jvc 52" made in july 2004 replaced bulb twice under warranty plus replaced ballast board in 2005 replaced bulb dec 2008 my tv was before and after install having a blue hue reversed words
Sep 01, 2008 | JVC HD-52Z575 52" Rear Projection...
Lamb will not reset
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
Open Questions:
427 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
