Question about Tecnik TKL9290 Front Load Washer / Dryer
Tecnik tkl9909 washer dryer doesnt dry
I have a tecnik tkl9909 washer dryer that is not drying. the drum turns but there is not hot air
5 Suggested Answers
SOURCE: LG all in one washer dryer fills with water on the drying cycle
I had the same problem with my machine this week and I discovered an auxillary drain that was clogged with lint. If you lift the inner lip on the bottom of the door gasket you will see a small hole. This hole is actually connected to a skinny tube that drains to the main water pump. Mine was clogged with lint and the water that had accumulated there was draining back into the drum and soaking the clothes again. I cleaned it out and blew air through it and now the machine works like new again. I hope this helps.
Posted on Feb 06, 2010
IFIXALL
  • 868 Answers
SOURCE: Tecnik 9290 washer dryer
Check for a low vent air flow,...Try removing the vent hose for just one dry and see if you correct any problem here.
Posted on Jun 01, 2008
aborcass
  • 2651 Answers
SOURCE: it takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Posted on Jan 14, 2009
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
It gets hot but doesnt dry
you will need to remove the front cover,by removing 2 kick panel screws at the base of the front of the machine,remove front cover and make sure blower wheel is turning,if so,then remove any heating ductwork and vacuum out all lint,this sounds like a restriction inside the machine for air flow
Mar 05, 2010 | Whirlpool Inglis IP8200 Dryer
May 01, 2008 | Tecnik TKL9260 Front Load Washer
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
339 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
