Question about Daewoo Refrigerators
I have A DAEWOO no frost multi-flow ERF-391AMI refridgerator. But de freezer is not working well its get gold but not freesing. And i do not now de meaning of the lights and buttons up on the top can you help me please.
2 Suggested Answers
SOURCE: fridge freezer leaking
there should be a drain pan under in unit. it could be missalinged or the drain tube may have a hole in it. mice are good about this
Posted on May 22, 2010
How to identify why my Daewoo ERF-364MNL fridge freezer is warm
This is a fairly common problem with most Frost free Fridge freezers. The system relies on regular automatic defrosting, and if there is a fault in that, the cooling cycle is seriously affected.
The problem could be as simple as a blocked defrost water drain tube, or more complicated such as a failed de-frost heater, defrost timer, or drain tray heater.
To check and repair any of them, is quite an involved process which involves stripping a lot of trim, and other parts just to get to them.
I would suggest that you get a qualified Refrigeration Engineer to repair it.
I hope this helps?
Feb 08, 2016 | Daewoo Refrigerators
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
The freezer works real fine, but the refridgerator will not cool down. sometimes the freezer frosts up behind the plastic barriers in back/ model fr662nb
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 22, 2011 | Daewoo Refrigerators
Fridge freezer leaking
May 22, 2010 | Daewoo Refrigerators
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
MY FREEZER FREEZING AND FRIDGE IS NOT COLD ON MY BLACK SIDE BY SIDE WHIRLPOOL
hi thanks for the question i would check to see if the fan in your freezer is working that could be the problem make sure the back of the fridge is clean where the compressor is located also make sure no frost has built up in freezer thanks the appliance doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
246 people viewed this question
Top Daewoo Refrigerators Experts
jasbo
jasbo
john h
John Tripp
John Tripp
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
