Question about Sub-Zero Refrigerators
My sub zero runs all the time, why? It works fine, but should'nt the fan/motor cycle on and off as needed?
    Problem Solver:
  • 15 Answers
Some subzero's run the condensor motor all the time. This is the motor next to the compressor. If you check the temp. and it is running normal then check the condensor coil and if dirty clean it. If it is clean and its cooling fine (you've checked the temp). You may have a bad t-stat also, but normally if your not freezing food that won't be the issue. Just clean the condenser and see if it runs less.
Posted on Feb 09, 2010
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
I have a Sub Zero 650. The fan on top runs all the time. The temperature inside both Freezer and Fridge are fine and will respond to the changes I do to the settings. The fridge had been off for a move and...
If either compressor is running the fan is always on to cool both compressors. As they cycle it is possible the both compressor cycle at the same time and the fan turns off. But it is rare to see this happen. So yes the fans for the compressor does run at the time. I hope this helps, good luck
Jul 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 736 condenser fan not running
You will need to remove the cover around the condenser fan motor then remove the screws holding it down to the base. Remove the wiring from the junction box and away you go. Do not run the unit without a working condenser fan motor, you run the chance of causing yourself many other problems. With a new fan motor the unit should run fine unless there is waxing in the cap tube from overheating. Good luck
Sep 08, 2012 | Sub-Zero Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
Cleaned condenser on sub sero 680f and now fridge is running high
Check to see if the condensor fan (underneath the refrigerator) and the evaporator fan (behind a panel in the freezer) are both running. If one of these is not running, the refrigerator will not have its full efficiency.
Oct 18, 2009 | Sub-Zero 680 / F
The fan keeps running by the motor
the fan must only run when the motor are running
May 15, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Sub-Zero 532 not cooling
Simple think I guess - just pull down a little a plastic fan blade on motor shift it will produce a powerful air flow. Fan blade should sit pretty close to the shift end. ;)
_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jun 11, 2008 | Sub-Zero 632 / S
Freezer not maintaining proper temp.
I think you might be just seeing the cycle.. it comes on reaches 0 stays off for awhile and kicks back down to 0.... wouldnt be to concerned unless it stays there
Sep 03, 2007 | Refrigerators
Refrigerators Logo
576 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
