Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
My Hotpoint refrigerater model HSS25GFPJ WW is not working properly. It began with the water dispenser decreasing in flow, then there was a smell that we were able to eliminate, and now the ice maker is not working. Any suggestions?
My GE side by side will not defrost
Posted on Apr 03, 2010
Decreased water flow from dispenser GE GSS25WGTA refrigerator
This is usually caused by the water inlet valve not opening all the way or it got clogged up. The valve assembly will need to be replaced, don;t try cleaning it out it will likely cause a clog further up the tube. They are usually pretty inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/referwaterinlet.html
Jun 23, 2010 | GE Refrigerators
No water is coming out of the water depenseron the refrigerater
does your ice maker work OK ? if yes , do you have a inline water filter in the upper right hand section of your refrigerator at the rear ? if yes , replace the filter and follow the directions on the new filter to properly prime the water dispenser line. if the unit will not prime with the new filter installed, you'll probably have to replace the water dispenser control valve located at the bottom rear of the refrigerator where the main supply water line goes into the refrigerator.
Mar 17, 2010 | Refrigerators
My hotpoint fridge dispenses ice, but not water. The filter has been changed. Model #HSS25GFPE WW
Set up a shop light, one of those Halogen type lights. And have it shining right on it at the highest setting. The water in the line has frozen. After about 30 minutes to an hour it should start working again. You could also use a blow dryer but I'd rather not stand in front of the fridge that long. Remember if you got kids in the house to warn them not to touch the light!
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Hi i have a hotpoint hss25gfpj ww side by side
Very common. Most likely you need a main control board, located in the back of the fridge.
GE refrigerator repair in orange county, ca
Feb 06, 2010 | Hotpoint HSS25GFP Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
No water at dispenser
apply hair drier to spout and surrounding area for a minute every ten minutes , after about an hour the ice that has formed will be loose enough for the water to come out of spout
Mar 28, 2009 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint hss25gfpe ww fridge with ice and water in the door. The ice works, but I am unable to get water. Why can I not get any water? The serial # is tf261776 if this is needed.
Most water dispensing fridges have a tank in the fridge to keep the water cold. If the fridge temp is too low it might freeze the tank and stop the water from dispensing. Also check the water filter to make sure it is not frozen. Water filters should be replaced every 6-12 months, if it's been longer than that it might be too full of dirt to allow water past. It also might be the water inlet valve is not opening.
Jul 20, 2008 | Hotpoint Refrigerators
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
181 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
