Question about Maytag Refrigerators
Water leaking from freezer side of side by side refrigerator..model MSB2354AR
    Problem Solver:
  • 11 Answers
Sounds like a clogged drain, If ice is on bottom of freezer floor then it is def. a clogged drain. Remove rear panel and clear drain of ice and possible obstruction.
Posted on Feb 09, 2010
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Water Leaking from Freezer Side of Refrigerator
Got a couple of questions before we can really say much Does the refrigerator/freezer appear to be running as normal? is it perhaps always running at the time the water leaks for longer or more noisily than normal. Is the temperature of the freezer as normal? is there a particularly cold patch in the refrigerator , probably at the back or on the freezer side near the bottom? Where exactly is the water leaking from? and is there water collecting inside? Does the door seal properly at the base where the water seems to be coming from? Is there another major appliance with a heavy current draw that always goes on at the same sort of time? I'm thinking a water boiler, or aircon/heater, or the oven etc. Please post back, and we can start running through possible solutions :)
Jun 28, 2007 | Jenn-Air JCD2389G Side by Side...
Ice maker water flow continously
That is cause by a defective dual water control valve. Just like a leaking faucet the water will continue to leak until the dual water control valve is replaced.
on Sears model refrigerators the model number looks most times like this example 321.256475
Below is a short video explaining how to on many refrigerators. If you have questions please post your questions here and I will be glad to help, Thanks Sea Breeze
Click Here for Video=> Icemaker Repair
Aug 28, 2012 | Kenmore 54603 / 54606 Side by Side...
Water coming from freezer into refrigerator otherwise appears to be working ok
I will try to give you a better idea of how and why this happens. The problem is that every different model has a different way of leaking. Like a side by side if the defrost condensate drain line is blocked the water will at most leak inside freezer. With a single top freezer the water may just leak down into the fresh food section. Click Here=> Leaking Refrigerators Just What may Be HappeningThanks, Sea Breeze
Jan 10, 2011 | Roper Refrigerators
Water leaking from under refrigerator model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
88 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
