Question about Canon imageRUNNER C3200 Copier
When printing, my Canon IRC2300 will print a large black bar (varying from 2-5 inches) in the middle of the page. After the bar the rest of the image does not print.
  • 58 Answers
Its probably your black drum unit that needs to be replaced
Posted on Feb 10, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more.. http://www.shopping.hp.com/shopping/data_sheet/cc567a.html
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon prograf w8400
GO ONLINE AND TYPE THE FOLLOWING:
CANON IMAGEPROGRAF W8400 INKJET PRINTING 2 INCH BLACK LINE
ENTER
SEE IF ANYONE ELSE HAVING THIS PROBLEM BEFORE, GET SOME HELP OR IDEAS ON HOW TO FIX IT
GO ON LINE TO
WWW.CANONUSA.COM/IMAGEPROGRAF
ENTER
ROD
Feb 10, 2009 | Canon imagePROGRAF W8400 InkJet Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Ink on backside of paper
Same problem appeared with mine, but one month out of warranty. Black streak of varying intensity up to 6mmm wide on reverse of sheet being printed. Repeated reuse of the "Bottom Plate Cleaning" utility (60 to 70 times) did not solve the problem. Seems the problem lies with the pipe that carries waste ink from the purging dock to the middle of the machine where there is a large ink absorbent sponge. This pipe (or tube) blocks up and excess ink then builds up, eventually ending up on the back of the paper being printed. Canon support refuses to accept that this is a design fault, and claims that it is a "mechanical fault" , not their fault as the warranty has run out. There may be an 18-month warranty in parts of the US, but for the rest of us it is 12 months. Took the machine to the local Canon-authorised repair shop who charged EUR80 to unblock the pipe. There was no breakage or other mechanical fault. It will block up again, and there is nothing you can do about it - just grin and pay the repairman. It is amazing that a defective design such as this is allowed to be offered in the shops.
Jun 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Pause/printer rest between pages
Hi nurse_boop (Lainey), You can try changing some of the printer settings. Assuming you're using Windows, go to Start, Printers and Faxes, and right click on your printer, choose Properties: 1. Make sure that you disable printer pooling; 2. Check/tick, print directly to the printer; 3. Check/tick, Printer is Always Available. Please keep in mind that large file sizes, images and deep colors adds to the slowdown and pauses of printers. Hardware wise, large documents requires more memory both on the printer server PC and the printer itself. Hope this be of some help to you. Post back how things are or should you need further information. Good luck and kind regards.
Aug 24, 2007 | Canon LBP 1120 Laser Printer
Canon imageRUNNER C3200 Copier Logo
112 people viewed this question
old marine
old marine
